since there has been plenty of talk... and no doing it...
intake manifold
5/16-18 x 2.5
valve cover
1/4-20 x 1
Crank pulley
3/8-16 x 1
Plugging Smog Hole (thermactor plug) 5/8-11
speed sensor clamp
1/4-20 x 3/4
Tps sensor screws
M4 x 0.7 pitch x 25mm length
intake plaque
8-32x1/2" taper seat machine screw
For those who need to plug their low oil level sensor hole
Oil plug M20 1.5 thread pitch
Edelbrock performer and typhoon upper plenum cover-
1/4x1 machine cap screws are a direct fit
Edelbrock performer and typhoon upper to lower studs-
5/16x1-3/8 carb studs.
Thermostat housing
5/16-18 x 1 3/4" for top left bolt
5/16-18 x 1 1/4" for bottom right bolt
Both bolts use split lock washers.
Battery hold down bolt
6mm x 1.0 x 55mm
87+ Wiper motor screw: 1.25" long blunt sheet metal screws. 1/4"-14 thread
Rear Shock 12mm x 1.75 x 70mm or you can use a 1/2" x 1.50" long bolt.
Quad shock axle housing mounting bolts(12mm x 1.75 x 70mm)
add what you have... we get a good amount i will put it in excel and put the torques and such also!
mods please sticky!
intake manifold
5/16-18 x 2.5
valve cover
1/4-20 x 1
Crank pulley
3/8-16 x 1
speed sensor clamp
1/4-20 x 3/4
Tps sensor screws
intake plaque
Thermostat housing
6mm x 1.0 x 55mm
mods please sticky!
If they are anything like my K member bolts they were half rusted through and two of them snapped completely off when I went to remove them! Speaking of which I will post those bolt sizes as soon as I get my new ones.
