M manny Founding Member Dec 5, 2001 590 6 16 TAMPA FL May 24, 2006 #1 May 24, 2006 #1 witch gauges should I use with a vortech supercharger a blower pressure gauge or a boost/vacuum gauge.
91ghp5.0 Active Member May 25, 2005 42 0 28 Somewhere May 24, 2006 #2 May 24, 2006 #2 boost/vacuum i guess
A Aaron'S'tang New Member Nov 10, 2005 58 0 0 Lake Geneva, WI May 24, 2006 #3 May 24, 2006 #3 manny said: witch gauges should I use with a vortech supercharger a blower pressure gauge or a boost/vacuum gauge. Click to expand... Boost/Vacume for sure, you'll want it to monitor how the s/c is doing at different rpm ranges. A couple of other guages would help monitor **** if you want to keep an eye on things.
91ghp5.0 Active Member May 25, 2005 42 0 28 Somewhere May 24, 2006 #4 May 24, 2006 #4 aka oil pressure (usually a must w/ blowers).
M manny Founding Member Dec 5, 2001 590 6 16 TAMPA FL May 24, 2006 #5 May 24, 2006 #5 i already got oil pressure that was my first cool thanks for the help
