boost/overheating problems
  • Thread starter Thread starter daemion_AF
  • Start date Start date May 1, 2004
D
daemion_AF
39
Lackland AFB TX
May 1, 2004
  • May 1, 2004
Well i finally got my headgaskets replaced, and i went along and got all new gaskets/bolts for everything and she ran good with no boost just really rich. I compression checked her earlier today and all cylinders were around 120-140 psi, not bad. I broke her in about 1500 miles or so, and decided id put the charger back on her today. So i hooked up the 12 psi pulley, threw in the 23 heat range plugs gapped at .30 and put the timing back to around stock (no gun just marks). Anyways at full throttle around 3000-4500 rpm she cuts in and out pretty rough. Ive had this problem before and it fixed it when i advanced the timing a bit over stock. So i play around with the timing all day today, and still no change. Any other suggestions to try? Next after all of the playing with the timing she started spitting coolant out of the overflow reservoir until she overheated...id fill the radiator back up and the overflow would bubble up until it spewed it back out. Would the thermostat getting stuck cause that, or do i need to run some cleaner through her or what?
D
daemion_AF
39
Lackland AFB TX
May 2, 2004
  • May 2, 2004
Ok solved the overheating problem today, my brand friggen new thermostat malfunctioned....woulda been easy to see my hoses balooning up if i wasnt so frustrated about the boost problems. Any ideas about the boost problem are still welcome.
L
Car has been overheating. Not sure what is causing it. Any help would be appreciated.
  • Luckysgirl
  • Jun 2, 2026
1996 - 2004 SN95 Mustang -General/Talk- Jun 2, 2026
Luckysgirl
L
Hi. I'm new. 98 Cobra Bent Axle.
  • sbk93036
  • Mar 28, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Oct 5, 2026
Mustang5L5
Project Fox Revival (please send help)
  • sleep-e
  • Jan 21, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jan 22, 2026
KRUISR
Forced Induction Total Timing under boost
  • Dontknowchit
  • Aug 27, 2025
Fox 5.0 Mustang Tech Aug 28, 2025
Dontknowchit
Engine Looking for suggestions and or ideas
  • PonyGTrider
  • Aug 25, 2026
PonyGTrider
