Boosted Vacuum ???
  • Thread starter Thread starter Detroiit
  • Start date Start date Aug 28, 2014
Detroiit
305
59
38
Detroit MI.
Aug 28, 2014
  • Aug 28, 2014
Can I hook a boost gauge to the other port on the pcv valve? I noticed a vacuum line not connected and determined it goes to the pcv valve.. on this same pcv valve is another capped off port. Can the boost gauge be hooked up here? If not ... Is it better to hook a boost gauge on the air intake or after the throttle body?
madspeed
Colonel Mustard
1,332
204
a van down by the river
Aug 28, 2014
  • Aug 28, 2014
boost gauge should come from a manifold vacuum source
MikeH686
Mine is only two inches though.
2,843
1,753
184
Waldorf, MD
Aug 28, 2014
  • Aug 28, 2014
The pcv is crank case which should not be in a positive pressure, that should be vented off and for a boost gauge you want it in the intake stream somewhere after the power adder
Detroiit
305
59
38
Detroit MI.
Aug 28, 2014
  • Aug 28, 2014
On the throttle body there is a hole on top that is plugged by a bolt and some electrical tape cause the hole isn't tapped(threads). is this a good spot for the boost gauge? Or ... can I hook it up to a capped port on the vacuum tree on the fire wall?
Detroiit
305
59
38
Detroit MI.
Aug 28, 2014
  • Aug 28, 2014
ALSO... does the pcv go to the upper manifold vacuum ports?
madspeed
Colonel Mustard
1,332
204
Aug 28, 2014
  • Aug 28, 2014
use the vacuum tree, and fix that hacked throttle body port. At least put a vacuum cap on it to ensure it is sealed off, or better yet, run the line to the port on the valve cover as Ford intended
MikeH686
2,843
1,753
184
Waldorf, MD
Aug 28, 2014
  • Aug 28, 2014
But since he's forced induction does he want to run it back to the valve cover? I would figure not since you'll be putting a positive pressure into the crankcase I could be wrong with my thinking but just thinking out loud here
Reactions: Detroiit
Detroiit
305
59
38
Detroit MI.
Aug 28, 2014
  • Aug 28, 2014
I was looking around the motor and I pulled a hose that wasn't connected to anything. I noticed upon further investigation that the pcv didn't have any hose hooked to it.. so I assume they should be mated?
the hacked throttle body port is just that a hole in the throttle body.. nothing is there or ever was there except a taped bolt. what should be there? its just a hole with no threads.
Detroiit
305
59
38
Detroit MI.
Aug 28, 2014
  • Aug 28, 2014
here is a pic with the rusted head of the allen bolt shoved into the hole.. right next to the tps.
and I will add it has a new bolt in it because the positive pressure pushed out the rusted allen bolt.
It was taped with electrical tape to bring it up to the inner diameter.
Detroiit
305
59
38
Detroit MI.
Aug 28, 2014
#10
  • Aug 28, 2014
  • #10
the port thats after the throttle body(in the pic nothing is going to it) next to the IAC motor, I connected the bypass valve to it for the supercharger.
If you notice in the pic, the tube coming off the valve cover breather/spout is a long tube not hooked to anything.. Did this used to go to that rusty allen bolt hole?
bentley429isBAC
922
188
84
CT
Aug 28, 2014
#11
  • Aug 28, 2014
  • #11
No.
Onefine88
Previously 89SSC18
1,422
796
154
Aug 29, 2014
#12
  • Aug 29, 2014
  • #12
Yes the hard plastic hose below the oil filler cap originally went to the spot you mention on the throttle body. Do NOT reattach that to the throttle body. Since it is supercharged it would force "boost" inside the crankcase. I would remove whats left of that line and cap it off and keep the hole on the TB capped off as well.
mikestang63
SN Certified Technician
Aug 27, 2012
11,606
8,859
214
In the garage
Aug 29, 2014
#13
  • Aug 29, 2014
  • #13
Cap off the nipple off the Valve cover. When I had a vortech I did not run a PCV. Instead I ran a hose off it with a catch can and a breather element..
7991LXnSHO
wanna catch the space herp
7,387
2,746
194
Kearney, NE
Aug 29, 2014
#14
  • Aug 29, 2014
  • #14
Especially boosted, you need the crank case to have some ventilation of blow by. A filtered air catch can breather from the valve cover on most cars, or from the PVC valve on an EFI 5.0, is a good idea. An open breather will usually put oil out on the motor. (See any pre PVC car.) and who really (besides the EPA) wants the oil vapor going back into the intake anyway?
TOOLOW91
20+ Year Stangneter
8,763
234
S.I.NY
Aug 29, 2014
#15
  • Aug 29, 2014
  • #15
bentley429isBAC said:
No.
No is correct you don't want to boost te crankcase . Mine is gone and the pcv is plugged with a filter until nick makes my VC and I put the catch can in
Detroiit
305
59
38
Detroit MI.
Aug 29, 2014
#16
  • Aug 29, 2014
  • #16
Last time I capped the line off I blew out the pcv from the intake on the big end of the track and smoked everywhere.
Detroiit
305
59
38
Detroit MI.
Aug 29, 2014
#17
  • Aug 29, 2014
  • #17
Im just so lost.. Lets start over.
1. Cap the breather line that used to go to the throttle body? (Last time I capped the breather line from the TB to valve cover hose I popped out the pcv and oil dripped on the exhaust and smoked something fierce and the end of my 1/4 mile run)
2. Keep a cap on the throttle body.
3. Should I add a breather to the pass valve cover?
4. Should I attach the upper manifold vacuum line back to the pcv valve or get a longer hose and run the hose from the pcv valve to a catch can? (Does a vacuum line need to go to the pcv valve?)
5. Can I plumb in my boost gauge to the hose that used to go to the pcv? (IF infact it is not needed)
6. How bout this what is the best way to go about getting this done right.. I am in Michigan and dont have to worry about emissions.
mikestang63
Aug 27, 2012
11,606
8,859
214
In the garage
Aug 29, 2014
#18
  • Aug 29, 2014
  • #18
Cap off the nipple on the TB and the VC where the hose would go. On the PCV valve, replace the stock PCV with a Turbo Coupe PCV as it is a one way valve and install a hose with a catch can and then a breather element and plug the nipple on he intake where the other side of the PCV hose. Or leave the PCV intake and install a breather element on the VC. The last option you will have unmetered air coming in and you may get some oil mist coming out the breather.
A
Catch can questions.
  • AngryH58
  • Sep 26, 2026
1996 - 2004 SN95 Mustang -General/Talk- Sep 29, 2026
squeak93
D
Please help with vacuum lines
  • Dawgs000082
  • May 10, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 10, 2026
Dawgs000082
D
G
Vacuum hose?
  • Gandalf79
  • Mar 5, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Nov 18, 2025
mayapril
M
Intake vacuum lines
  • cnorman31
  • Mar 9, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 15, 2025
Scrapla347
Mustang II 4 cyl gear hunting and possibly messed up vacuum system
  • oesterreicher
  • May 31, 2026
1974 - 1978 Mustang II Talk & Tech Jun 14, 2026
manicmechanic007
