boring over ?? stroker kits??
  • Thread starter Thread starter 302RWP
  • Start date Start date Feb 13, 2004
302RWP
100
Northern California
Feb 13, 2004
  • Feb 13, 2004
hey all i got another question for you guys. what exactly does it mean when your engine is bored over? is it the same thing as a stroker kit? im guessing they just increase the cylinder chamber so more fuel and air can get in, but can someone explain in detail?? thanks
6Stang7
1,470
Livermore, CA
Feb 13, 2004
  • Feb 13, 2004
There are two messurements that decide what your cylinder displacment is, your bore and stroke. Bore is the diameter of your cylinder (size of the hole) and the stroke is the distance your piston travals from TDC (top dead center) to BDC (bottom dead center). When you bore and engine over, let's say .030, you increase the size of the hole by .030. When you stroke a motor, you change the offset distance between your main journal to your rod journal, which decides what your stroke is.
-Shaun
Swede958
712
Austin, TX
Feb 13, 2004
  • Feb 13, 2004
6stang7 hit it pretty solidly. If you are not technically minded and do not understand what he meant about the offset he's talking about, just check out his avatar. When you stroke a motor, the piston will just move deeper down the cylinder than it normally would.
THe Swede
Weber Carburetor tuning help
  • SchwarzStock
  • Jul 6, 2026
1965 - 1973 Classic Mustangs -General/Talk- Jul 19, 2026
SchwarzStock
M
01 mustang 3.8 fuel pressure issue
  • Mhaley2006
  • May 29, 2026
1996 - 2004 SN95 Mustang -General/Talk- Aug 9, 2026
JohnKay
J
Need some camshaft guru advice on power loss from supercharger to nitrous
  • TTSaleen
  • Dec 1, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Dec 29, 2025
revhead347
W
Speedometer and shifting issues
  • wyatt-tetro891
  • Aug 17, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 18, 2026
wyatt-tetro891
W
Engine Suggestions on an engine rebuild. Stock cam/GT40Ps or aftermarket on both for a fun weekend driver?
  • MadSquirrelTech
  • Apr 28, 2026
Fox 5.0 Mustang Tech May 7, 2026
MadSquirrelTech
