- Mar 31, 2005
- 59
- 0
- 0
So both my door handles are still physicalliy there, but it feels like there is nothing attached to them. Door still opens fine from the inside. So do I just have to buy replacement exterior door handles?
What size carriage bolts do I need?
There is a metal rod inside the door that can get bent, or a couple of plastic components could have broken.I have the new exterior metal door handles from Latemodel Resto, however does anyone have a clue why the door wouldn't open from the inside?![]()
You will probably have to pull the door panel to inspect it better.
Pack a handful of tools and head for the junk yard...Worst case, if the rod is bent, bend it back? And what if the components are broken?
Nevermind. Fixed.
it turns out that somehow the rod just popped out of the door handle? So it was an easy fix.
*knock wood* my handles are still stock. time to replace the power lock switches though. they are being annoooyyying.
HAPPY NEW YEAR GUYS!![]()
Good suggestion but I prefer to use NEW PARTS whenever possible.
And yes we do celebrate New Years... and no we don't live in igloos
EDIT... I see you're in the Seattle area so you probably already knew that didn't ya![]()
Those of you who have replaced the door handle: is removal of the inside door panel necessary? My driver's side handle on my '90 LX recently broke but is still functional IF you push in while pulling up on the handle. I have the replacement parts from 50resto.com and I know you have to drill out the stock rivets. My brother-in-law once had to do this on one of his mustangs and he ended up taking the door panel off for some reason or another (I didn't watch - didn't have my Mustang at the time).
I removed the panels when i changed my handles.It takes less than 10 mins to remove and it makes the job alot easier to do.If your going to use rivets to reattach the handle you might be able to get away without removing the panel....i'm not 100% sure on this because you have to reattach the linkage to the handle.It might be a pain in the azz to do through the small opening from the handle.
IMO....I say remove the panel and save yourself a hassle.![]()
