Both Door Handles Broke.
Carriage bolt is a great idea! I used rivets this past weekend and ended up scratching the door. Careful using the rivet gun, it can kick like a mule. Guess sometimes you learn the hard way. Have the passenger side to do still, this time I'll know better.
i hade to replace the handles also .So i bought and put on the aftermarket handles and took them right off because they looked cheesey.So i spent the money and got the ford original handles .Thats my advice
sometimes if you have the key in the door and turned to unlock to door, and u pull the handle. the metal rod will come undone. you can get down and look at the handle and see if its broken or not.
Hi, My drivers side door handle broke too. I took off the mirror adjusting thing, the inside door handle and the armrest. The thing still doesnt want to come off. As far as I can tell there's nothing else holding it on. What i've been told is you have to pop the clips off along the bottom inside of the panel and once those are off push the whole panel upwards to release the top clips. If that is the right way it sure isn't easy to do. Any advice anyone can give me about tools or methods would be greatly appreciated. Thanks in advance. P.S. I hit the junkyard on a hunch and discovered that a certain old ford station wagon (not sure what it was, 70's or 80's i'd assume) had the same handles on the rear doors as our mustangs in chrome! Payed like five bucks for both. I drilled out the rivets and I pretty much tore them off since I didn't care about the station wagon and then just bent the arm with the hole in it back to its position once it was off. Not the best way to do it but I couldnt get the panel off of those doors either lol.
