Both windows sqeaking when going up.
  • Thread starter Thread starter savegoodautonfg
  • Start date Start date Jun 16, 2006
1 of 2 Next Last
savegoodautonfg
1,085
  • Jun 16, 2006
Both of my windows are sqeaking when they go up its really ear piercing now and i want to fix it.
What can i do to resolve this issue?
bill302
2,131
alabama,gadsden
Jun 17, 2006
  • Jun 17, 2006
remove door panels and grease the window tracks if that doesnt fix it while the panels are off operate windows and see if you can locate where the squeak is coming from the window slides up and down against a pad this pad may be worn and need replacing.....
powertrax91
598
New York
Jun 17, 2006
  • Jun 17, 2006
you might need to replace the door belt molding weatherstrip, or the weatherstrip around the window frame, or both...
they came from the factory with a felt coating that and has worn away over time, your moldings are squeeking like new sneakers on a freshly refinished basketball court.
Roland69
Sergeant Tangnet
Sep 17, 2005
2,867
Port Elgin, Ontario
Jun 17, 2006
  • Jun 17, 2006
maby some sand or grit in the felt....but try what Bill302 said aswell...or an easy way would be to go to a rust check or Krown and have them drill a small hole bt the bottom of the boor and stick the oil spray rod in your door and soak the hell out of it.
savegoodautonfg
1,085
  • Jun 18, 2006
Can i have links please to 50 resto on these items?
89lxsport50
550
Franklin Tennessee
Jun 18, 2006
  • Jun 18, 2006
basketball court.
That's what fixed mine.
C
criticman
723
Rome, GA
Jun 18, 2006
  • Jun 18, 2006
A quick fix that has worked for me is to take a can of WD-40, attach the "straw" sprayer, and spray it down between the molding seal and the window glass. Then bring it down and back up a few times, repeating as necessary with the WD-40.
You'll need to clean the window when done (likely will have streaks on it from WD-40 and any grit loosened up).
Worked wonders for me.
Good luck.
Roland69
Sergeant Tangnet
Sep 17, 2005
2,867
Port Elgin, Ontario
Jun 18, 2006
  • Jun 18, 2006
wont that leave a film for a long time after cleaning the window after
C
criticman
723
Rome, GA
Jun 18, 2006
  • Jun 18, 2006
Nope. For one, you could clean your window with WD-40. It breaks down dirt/grime, and wipes away fairly clean. (I wouldn't recommend it, but you COULD).
Just clean the window with a good cleaner (read "not amonia based") and there will not be any glare/streaks.
I have no A/C now, so windows go up and down a lot and the noise is gone thanks to WD-40.
Roland69
Sergeant Tangnet
Sep 17, 2005
2,867
Port Elgin, Ontario
Jun 18, 2006
#10
  • Jun 18, 2006
  • #10
cool that's good to know...My truck could use that treatment lol
powertrax91
598
New York
Jun 19, 2006
#11
  • Jun 19, 2006
  • #11
here ya go
http://www.latemodelrestoration.com/iwwida.pvx?;item?item_no=LRS-20934-K 1&comp=LRS
http://www.latemodelrestoration.com/iwwida.pvx?;item?item_no=LRS-21596K 1&comp=LRS
Joey5.0
313
Usa
Jun 19, 2006
#12
  • Jun 19, 2006
  • #12
Wax your windows. Sounds stupid but it works man
savegoodautonfg
1,085
#13
  • Jun 19, 2006
  • #13
powertrax91 said:
here ya go
Thanks for the links but there's no way i can afford it. what else are some options and if i have to redo it every once and while its not the biggest deal?
blue302stang
61
#14
  • Jun 19, 2006
  • #14
my car did this for a while too, and was annoying as hell, but eventually just stopped doing it all together.
savegoodautonfg
1,085
#15
  • Jun 21, 2006
  • #15
bump
C
criticman
723
Rome, GA
Jun 21, 2006
#16
  • Jun 21, 2006
  • #16
As we've said, WD-40, wax windows, etc. Sounds odd maybe, but it does work.
That's your best budget method. Otherwise, spend the money on replacement parts.
Good luck.
Joey5.0
313
Usa
Jun 21, 2006
#17
  • Jun 21, 2006
  • #17
Wd-40 is messy, just wax em Man
savegoodautonfg
1,085
#18
  • Sep 18, 2006
  • #18
I tried WD-40 already. now the noise or wahtever is starting to scratch my tint which is real bad. my tint had long scratches in straight lines all on the window. i hate it. its starting to really piss me off. i took the door panel off and used the WD 40 on the window tracks and worked for 3 days or so and started up again. theres all sort of sh it on my window from the inside now and it won't come off with any window cleaner.
savegoodautonfg
1,085
#19
  • Oct 28, 2006
  • #19
bump please
superhuaman
907
Harrisburg, PA
Oct 29, 2006
#20
  • Oct 29, 2006
  • #20
eww dont use wd40, the glass guy that replaced my windows said to use glass cleaner or water to lubricate the rubber/metal when installing the new weatherstrip. he also said to use silicone spray on the rubber where it touches the glass, only on the sides, not on the top. i made that mistake and had to replace mine again. silicone will stay around longer than wd-40. its also good for keeping your door seals from sticking to the door.
1 of 2 Next Last
Front window issues
  • bruno
  • Nov 7, 2026
Fox 5.0 Mustang Tech Tuesday at 10:26 PM
AeroCoupe
D
Electrical Weird door wiring issues
  • Dakar09
  • Oct 20, 2026
Dakar09
D
M
Bad starter?
  • mason5.0
  • Oct 6, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 6, 2026
General karthief
J
Suspension Foxbody mustang Steering shaft issue
  • Jakub2537
  • Sep 5, 2026
Fox 5.0 Mustang Tech Sep 11, 2026
gkomo
Paint and Body Door Latch Issue
  • KRUISR
  • Oct 9, 2026
Fox 5.0 Mustang Tech Oct 15, 2026
General karthief
