Well my bottom end just went out on me, so now it the perfect time to upgrade. I want to use my top end that I have right now, you can check my sig for what I have had done so far. I want a twin turbo car that has about 600-650 at the rear wheels. What block should I get to accomplish this. I was thinking a 347 Dart block, Eagle forged crank, Eagle h-beam rods, Diamond racing forged low compression pistons with TFS valve releifs. Do you think that is a good choice? If so, where can I get a good quality block from?
Here is what I want to do with the rest of the car, so let me know if I am headed in the right direction. And let me know if you have any experience with anyone in Michigan or close that will do this kind of work.
Upgrade the suspension: Install Maximum Motorsports Road & Track in a box, good choice? I want a street car, not a track car.
Upgrade the cooling system: Ford Racing Radiator, Mark VIII electric fan, 180 balanced stat, high flow water pump, 130 amp alternator, new hoses.
Upgrade the braking system: I would like to go discs all the way around, not sure what brakes I want as of yet, so any suggestions would be great. I think i am torn between the baer setup and the Ford MK2000, any suggestions
Get the new block, add my top end, upgrade the fuel system and add twin turbos.
Let me know if you have any ideas or info on what you would do next Or if I am missing something.
Thanks
Jason
Thanks
Jason
