Progress Thread Bottomless Pit
I call her that because all I do is sink money in to her. So this summer I am going to try to get a load of work done and install all the parts I already have. I have some money put away for some tires, I have a 255LPH fuel pump, shocks & struts, rear upper and lower control arms. I would also like to fix the trans leak, replace the master cylinder and brake booster, and the heater core. I am making this thread to hold me accountable. So here are some preliminary pics.
I fully regret the comment I made, can an admin or mod delete that or edit it out?
It wasn't fun or exciting to drive a car with bad brakes but past experiences can be laughable at times.
While driving in that state I was ALWAYS driving way behind everyone going 5 or 10+ under the speed limit. The stop light comment was just an exaggeration gone wrong.
Don't take it too hard bud. Alls well. Everyone does dumb stuff. Don't think anyone's gonna burn ya at the stake...this time
I reaaalllly don't want to come off like an azz, but a couple of suggestions for what it's worth
Don't move that car until the MC is fixed- that is scary looking and can get someone killed.
Those lower control arm bushings have poly bushings on both ends- those put a major stress on torque boxes and squeek like crazy. Check your torque boxes before you install them and at a minimum weld up the seams. Not trying to make you spend more money, but I'd sell them and get a good set like the MM or Steeda ones with the spherical bearing on one side. Same for the upper control arms. On a street car the poluy bushing cause major bind. All you need is replacement stockers or 94-95 rubber bushings in yours .
You have a nasty trans leak that needs to be taken care of. AOD's can fry up with low fluid levels. Check you tailshaft housing seal and bushing.
man bro?...i have a set of sve upper and lowers in a box at home i was goin to install next weekend!....its the only thing i cheaped out on with my whole build,thought it would be fine for my street/strip car,now im really doubting my perchase even more!.....stop making sense!,gona cost me $$$!...lol...
I feel like I need to clear the air here. Yes that MC is absolutely the worst, but the only problem with the brakes is there is air in the lines. The peddle is a bit soft, but I have no problem stopping the car. Also the trans leak just started yesterday, and obviously that needs to be fix immediately. Unfortunately, this is my daily driver, but I am working on getting another DD so when things like the trans leak occur, its not a huge deal. Also the rear upper and lower control arms are not going anywhere, I understood what I was getting myself into when I bought them.
