bouncing needles on new gauges
mach1one
Boulevard Bruiser
4,775
Living in the past
www.mach1style.com
The coolant temp. guage never worked in the 73 mach, so I decided to update it with new guages (along with the oil pressure/volt. guage) while troubleshooting the problem
With a new sending unit the guage doesn't read, it just bounces below 100; even with the car warm. To test the wiring I ran a new line directly to the sending unit, didn't fix it.
The oil pressure guage is now acting the same way. It bounces around way too much to work right. Before the guage swap it too was working.
The alternator guage is working right and has always worked.
Is this the symptoms of the IVR being bad? I only have a schematic out of a haynes manual and I'm having problems understanding it. Wiring is not something I understand very well.
The wire that goes to the sending unit is actually the ground wire. The sending units provide a certain amount of resistence which keeps the needle from pegging one side or the other. Make sure you have your wires setup correctly. Try running a wire directly from a regular 12v source to the gauge and then another to the sending unit. Actually, don't try that unless the guage can take 12v continuous. I'm not sure if your aftermarket gauges need an IVR. Check the instructions for the gauges and see if they need one, otherwise by pass it.
bouncing needles(or pegged) on the autometers I used in my neon always had bad grounds...my oil pressure didnt bounce since the Isolator acted as the ground through a stainess steel line....however if it isnt getting a good ground through the engine, you can always run a ground line to the frame as well(for the isolator...I had it setup like that once) anyway for the other gauges doublecheck all wiring and grounds...I assume you have all your splices soldered right?
The IVR wasn't hooked up; originally I wasn't sure if it was suppose to be.
So here's an interesting conclusion. I went to check the engine/chasis ground and there was none! So I bought one, installed it, problem solved.
The previous owners had also wired the guages such that they were on. So we swapped that over to a switchable power source too. Now if I can just get the gauges mounted I'll be all set :)
