  • 1994 - 1995 Specific Tech
Bouncing speedometer needle?
  • Thread starter Thread starter MrStang123
  • Start date Start date Jul 15, 2007
MrStang123
65
NY
Jul 15, 2007
  • Jul 15, 2007
Lately the speedometer needle has not been steady. It has been wiggling around the speed the car is at and the when you hit a bump the needle will hit 0 mph and bounce back to where it was at. Would this be a problem with a fuse or sensor? Or just some simple little part that needs to be replaced?
The Green GT
No 13 year olds are safe around me.
1,269
Louisiana
Jul 15, 2007
  • Jul 15, 2007
Sounds like a loose wire to me.
Check the speed sensor on the tranny and the wires on the back of the cluster. Id put my money on the speed sensor though.
MrStang123
65
NY
Jul 15, 2007
  • Jul 15, 2007
If is indeed a bad speed sensor how much does that piece run?
The Green GT
1,269
Louisiana
Jul 15, 2007
  • Jul 15, 2007
http://www.latemodelrestoration.com/iwwida.pvx?;item?item_no=LRS-9731A 1&comp=LRS
Like $30. But its probably just a wire.
GTA_V6_Mustang
1,326
Miami, FL
Jul 15, 2007
  • Jul 15, 2007
Actually to me it sound like the little motor that runs your speedo needle is taking a crap on itself. Mine was like that for a while. I took it out adjusted it (the little magnetic tips) and it was fine for a while then it got bad again and i took it out and so on untill now i just ignore it and I know how fast I am going by rpm and gear. Till I get around to going to a junk yard and getting that little motor to replace mine.
J
jmhkas
82
Bowling Green, KY
Jul 16, 2007
  • Jul 16, 2007
I always had a problem with the speedo gear getting stripped, but it was the crappy...23 tooth I believe?
M
1996 GT Speedometer electrical nightmare
  • moon96gt
  • Oct 7, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Oct 17, 2026
CAMTWO1070
70 Mach 1 with Fluctuating Speedometer below 40mph
  • 70 Mach
  • Oct 19, 2025
1965 - 1973 Classic Mustangs -General/Talk- Jan 19, 2026
Realmongo
J
'96 Cobra: A/C gets weak and engine misfires under load when warm
  • jruhnke
  • Oct 22, 2025
  • SVT Tech Forum
SVT Tech Forum Nov 20, 2025
nickyb
Engine Defective PIP sensor ?
  • bock
  • Sep 5, 2025
2K
Fox 5.0 Mustang Tech Oct 11, 2025
Mindseye007
A
P0036 P0056 P0137 P0157 2020 Ford Mustang GT
  • AmkoA
  • Jun 16, 2026
  • 2024+ (S650) Mustang -General/Talk
2024+ (S650) Mustang -General/Talk Jun 16, 2026
AmkoA
A
