70 Mach 1 with Fluctuating Speedometer below 40mph
70 Mach
Western PA
My 70 Mach 1 has a 351C engine and FMX transmission with a jumpy speedometer below 40 mph. This model also is equipped with a Distributor Modulator Speed Control Sensor between the transmission and the cluster (Part # DOAF 9E731). Could this be part of the problem? It's strange because over 40 mph it's fine.
Most likely it's a "resistance" or "drag" problem. When the cable has some drag on it from a lack of lubrication or a tight turn in it.... could be the DMSC sensor also. Once it spins fast enough it overcomes the drag problem and stops slowing down and then "releasing" the cable as torque builds up, which is causing the bouncing speedo.
