Boxing the Stock Control Arms. Worth it?
  • Thread starter Thread starter 5LugFoxFanatic
  • Start date Start date Apr 4, 2005
5LugFoxFanatic
LOVE AND PEACE!
1,058
Arctic Tundra Hell, Twin Cites, Minnesota, USA
Apr 4, 2005
  • Apr 4, 2005
I bought all poly bushing and am toying around with boxing the control arms. Is it worth it? I auto X my car so I am looking for handling without breaking the bank. Here's what I was reading. http://www.oldwestracing.com/index.html?http://www.oldwestracing.com/articles/armsbox/BCAwo.htm
trevnut
67
Mustang,OK
Apr 4, 2005
  • Apr 4, 2005
i did it to mine made a big difference
as long as you put poly bushings in them you be ok
rd
3,316
63
109
Ocean Springs MS
Apr 4, 2005
  • Apr 4, 2005
I welded up both a set of uppers and lowers, but I still have 1980 vintage rubber bushings in them because I want the torque boxes to live a bit more.
I am getting high 1.80 sixty foots, with old Lakewood traction bars.
If you put poly bushings in, I am sure you could tell a difference.
If the geometry is what you want, I recommend it.
5LugFoxFanatic
LOVE AND PEACE!
1,058
Apr 4, 2005
  • Apr 4, 2005
how much harder is it on the torque boxes if I do not drag race, and drive it on the street and use t for autocross twice a year?
Mavrick
2,264
Collingwood, ON
Apr 5, 2005
  • Apr 5, 2005
Hard poly urethane bushings on both ends of your controls arms is BAD for autox. The rear end can not move around as it is forced through corners etc. This is bad. Can cause snap oversteer and other unwanted characteristics. Do a search on MFE over on the Corral and you should find all the info you need.
Do not box the upper arms, but boxing the lowers should prove to be beneficial.
RED92VERT
74
  • Apr 5, 2005
Id just replace the stock control arms with some aftermarket control arms.
5LugFoxFanatic
LOVE AND PEACE!
1,058
Apr 5, 2005
  • Apr 5, 2005
I did a search and didn't find anything on the Corral. Well if it is bad to use poly bushings in the rear, I might have to think twice. But keep in mind, this is a car that sees track time 2-3 times per year.
Why not box the uppers? I have seen many tech articles outlining this. Is there a disadvantage to boxing them, other than a waste of time if they serve no benefit by boxing.
Aftermarket control arms? I wish, my budget is almsot gone for this year on my car, so that is not really an option.
hotrodnut
672
North Florida
Apr 5, 2005
  • Apr 5, 2005
Yes, boxing the control arms will help, when I replaced mine I could twist the stock ones by hand that is how flimsy they are.
As far as hard bushings go, I have the poly bushings in the lowers on both ends but rubber in both ends of the uppers. You should run a stock style rubber bushing at least in one end of the uppers to prevent binding while it travels through its up and down extremes.
I also use a panhard bar which limits side to side movement helping limit control arm binding so it is not as critical for the upper bushings to be as solid for supporting lateral movement.
5LugFoxFanatic
LOVE AND PEACE!
1,058
Apr 5, 2005
  • Apr 5, 2005
So....
Box both upper and lower arms,
Use poly on the lower arms on both ends
Use rubber in one end of the uppers and poly on the other end.
Sound good?
hotrodnut
672
North Florida
Apr 6, 2005
#10
  • Apr 6, 2005
  • #10
5LugFoxFanatic said:
So....
Sound good?
Yes
Yes
Yes
Yes Sounds like a good plan to me.
millhouse
1,985
Simpsonville, SC
Apr 6, 2005
#11
  • Apr 6, 2005
  • #11
Go here and read this Mustang Suspension Basics
And then go here and read this Maximum Lowers
And then this Maximum Uppers
04sleeper
2,674
14
89
Dallas, TX
Apr 6, 2005
#12
  • Apr 6, 2005
  • #12
Good info there millhouse.
westridez
68
#13
  • Apr 6, 2005
  • #13
what would be the best thing to do if you want your car to handle good in corners leave the control arms stock
millhouse
1,985
Simpsonville, SC
Apr 6, 2005
#14
  • Apr 6, 2005
  • #14
Read the links in my previous posts.
New Products From J&M Products - 1979-1998 & 1999-2004 Race/Extreme Duty Rear Lower Control Arms
  • J&M Products
  • Oct 9, 2025
  • Vendor Sponsor Forums
Vendor Sponsor Forums Oct 9, 2025
J&M Products
  • Gulftown980x
  • Jul 29, 2026
  • SN95 4.6L Mustang Tech
squeak93
Suspension Foxbody ride height change after installing new control arms
  • Mhalc1
  • Jan 3, 2024
9K
Fox 5.0 Mustang Tech May 10, 2024
Mhalc1
Wheels-Tires Quad shock quandry
  • gearhead77
  • Apr 22, 2024
2K
Fox 5.0 Mustang Tech Apr 27, 2024
Jarhead67
J
  • B0udreaux
  • Jul 14, 2026
AeroCoupe
