I just installed a brand new SSBC Force 10 front disc brake kit and was in the process of bleeding today. After bleeding the rears, I went up front and noticed a puddle of brake fluid under the right front caliper. Closer inspection, I could see the leak was coming from the brake line connection at the caliper. I tightened the line thinking the brass crush washer wasn't fully seated - still leaked. I removed the line to see what was going on and here is what I found:
You are looking at a closeup of the brake line connetion on the caliper. As you can see, there are very deep grooves machined into the surface, which are preventing the brass washer to fully seat and seal the line. I checked the other caliper for leaks and it too is leaking, although very slightly, but both calipers have the same grooved surface. I am going to call SSBC on Tuesday and arrange to return/exchange calipers. I wanted to post on Stangnet to get feedback just in case they are supposed to be like this, although I can't imagine this is the way they should be. I'm pretty miffed since I wanted to complete the brakes this weekend and finally test them. This will now likely take another 2 weeks of shipping parts back and forth before this is resolved. Appreciate the feedback.
As usual, StangNet Rules! :SNSign:
