brake conversion
vobraman
144
I badly need to do a disc conversion on the front. Have a 67 Coupe with manual brakes. I have been looking at stainles steel kit. Do I have to stay with manual or can I switch to power ? Is there a big advantage with power over manual ? Do I have to change my current brake pedal? The car is set up for street and will be running in the 11's. I will post some pics next week.
Any help is welcome
thanks
brian
Any help is welcome
thanks
brian
Yes you can switch to power if you want too you just need to add a power booster and order the correct parts for it, IIRC the push rod changes on power but the pedal bracket itself stays the same...I am sure I will be corrected if I am wrong. However, are you sure you want to switch to power? If you are running an 11 sec car will you have enough vacuum to support power brakes?
I run SSBC manual discs in the front and rear of my 65 and the stopping power is awesome. And I have an extra heavy cleveland to make stopping more fun.
if i can run with manual then thats is what I want. Do not want to spend more $ than needed
Well then you have your answer...now try this on for size...have you looked at Baer? They make some very nice braking kits are have a higher performance reputation than the SSBC....I chose the SSBC for my ride becuase I had I high familiarity with their product and knew just how easy it was to install the disc brakes (only a few hours) and at the time I knew nothing about the Baer products...if I had it to do over again, I would prob by the Baers.....they do cost a little more though.
I will check there web site and see what they have to offer.
thanks
Although the Baer brakes look awesome, there is some arguements out there with regard to Baer and other cross drilled systems.
Cross drilling was a practice originating in race cars designed to reduce the weight of the rotor while the cooling properties are minimal if any.
The holes have a tendancy to spider crack under heat strain and can reduce the overall life of the rotor by 50%...
Slotting on the other hand is more beneficial and functional in the reduction of gas build up and brake fade. This set-up is better for longevity and performance on a street driven ride...
