  • 1994 - 1995 Specific Tech
Brake issues!
  • Thread starter Thread starter stanglover0526
  • Start date Start date Aug 23, 2011
stanglover0526
55
missouri
Aug 23, 2011
  • Aug 23, 2011
I have a 94 Gt that has upgraded brakes off a 99-04 model. When i got the car the front brakes were a little hung up but i thought no big deal the slide pins need cleaned up and regreased. Well yesterday i took it all apart and greased them and took it for a ride and sure enough it didnt fix my problem. Clearly the pistons arent going all the way back in as i found when i took it all apart. Anyone have any ideas? I cant imagine both calipers being bad at the same time? Thanks for any reply
SableSal
295
Fresno, Californ-I-A
Aug 23, 2011
  • Aug 23, 2011
In order to properly install those brakes, the knuckle has to be grinded down for the bracket will fit properly. i just wanna make sure that was done on both sides. I'm assuming it was.
stanglover0526
55
missouri
Aug 23, 2011
  • Aug 23, 2011
I bought the car with the brakes already installed. When i took them apart to grease the slide pins everything seemed correct and there didnt seem to me any issues.
VibrantRedGT
"STANGNET'S PENGUIN SMACKER"
424
154
Boca Raton, Florida
Aug 24, 2011
  • Aug 24, 2011
They won't install correctly without shorter slide bolts or grinded down like mentioned above. Just because they are newer calipers doesn't mean the piston will never rust and hang up in the housing. They are still 10+ years old. I'm guessing they are the aluminum PBR calipers. You could always remove them and install a rebuild kit (new pistons, rubber o-rings and slide pins). Either that or buy new remanufactured units or Cobra calipers (both with lifetime warranty). I wouldn't trust having sticky front brakes when 65% of the braking is done up front. Also with a piston that does not retract will cause the pad to hang on the rotor which means excessive pad and rotor wear.
stanglover0526
55
missouri
Aug 25, 2011
  • Aug 25, 2011
I realize the calipers could be bad im just trying to find any other cause efore i spend the money
A
Help Needed! 2012 S197 brake caliper dimensions
  • AussieDavid
  • Mar 28, 2026
2005 - 2014 S-197 Mustang -General/Talk- Mar 28, 2026
AussieDavid
A
G
Auto City Classics 67-70 Mustang disc brake kit question/s
  • GOvert
  • Jun 30, 2026
1965 - 1973 Classic Mustangs -General/Talk- Jun 30, 2026
GOvert
G
H
Strange steering/brake issue
  • Haxmaster
  • Jun 2, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Jun 3, 2026
squeak93
Brakes Sealant for passenger side brake line fitting? (Weatherhead 7828)
  • dan50
  • Nov 9, 2025
Fox 5.0 Mustang Tech Nov 12, 2025
dan50
Brake issue after changing pads and rotors
  • squirrel0420
  • Jul 14, 2025
2005 - 2014 S-197 Mustang -General/Talk- Jul 18, 2025
nickyb
