Overpriced for what it is.
It's basically modified Ford parts. The front brake setup and i assume the MC are straight off an 84-86 Mustang SVO. Same front rotors as you currently have but obviously slotted with a 5th lug. The calipers appear to be SVO 73mm units. This is the same brake setup on 84-92 Mark 7's
The rear setup is a seldom used 92-93 rear 5-lug 10.5" VENTED rotor used on the 91-92 Mark 7, the 91-93 Saleen Mustang and the 1993 Cobra R. Those are the only vehicle it appeared on. It's basically a modified 87-88 t-bird setup that was again modified in 1994 to the current SN95 brake setups (10" and 11.65").
For $400 more, you could just get the M2300K kit and have MUCH better, larger brakes and be able to run ANY wheel. The above setup has issues on the front wheels. Not all will fit, mainly the center cap has clearance issues
