Brake lights staying on
  • Thread starter Thread starter IGN65
  • Start date Start date Aug 27, 2011
I
IGN65
9
  • Aug 27, 2011
I have a 65 coupe and have changed the brake light switch. The brake lights are on or just one is on. Is this the turn signal switch? It feels sloppy and needs changed any way. Thoughts?
J
JamesW
64
Central Texas
Aug 27, 2011
  • Aug 27, 2011
All you touched was the brake like switch on the pedal? Is it adjusted properly?
Rusty67
20+ Year Stangneter
Dec 3, 2002
3,749
37
109
LA, CA
Aug 27, 2011
  • Aug 27, 2011
Disconnect the electrical connector that plugs into the switch. If there is no change the switch isn't your problem.
I
IGN65
9
  • Aug 27, 2011
Thanks! Will give that a try.
I
IGN65
9
  • Sep 2, 2011
Found the problem! The new switch was installed without the proper bushings and washers. BTW, there is no adjustment for the switch on this type setup. If you don't have a shop manual, get one. It will save aa lot of time and guess work.
HDTony
134
Plainfield IL
Sep 4, 2011
  • Sep 4, 2011
well there is some adjustment, but it involves a file, when I replaced the rod from the pedal to the master, my brake lights wouldn't turn off, I filed the back end of the rod a bit and it loosened up the connection at the switch allowing it to turn off when releasing the pedal.
A
1966 Mustang coupe / Brake lights and left rear turn signal not working.
  • ArizonaRob1966
  • Nov 3, 2025
Classic Mustang Specific Tech Dec 24, 2025
Mcmahst
O
1967 Manual Drum Brakes , replaced the master cylinder and the brake light switch but the brakes lights stay on.
  • OldNSloww
  • Jul 14, 2025
Classic Mustang Specific Tech Jul 16, 2025
horse sence
68 headlights hot working
  • Butchd88
  • Aug 1, 2026
1965 - 1973 Classic Mustangs -General/Talk- Aug 3, 2026
Butchd88
D
Theft light staying on car starts right up
  • dtarang
  • Aug 13, 2026
1996 - 2004 SN95 Mustang -General/Talk- Aug 15, 2026
dtarang
D
2003-04 Mustang Cobra Brake Conversion
  • Cassiebaebae
  • Oct 8, 2026
1996 - 2004 SN95 Mustang -General/Talk- Saturday at 11:27 PM
Bib36`
