Brake Lines
  • Thread starter Thread starter Hg80Design
  • Start date Start date Aug 12, 2008
Hg80Design
68
Houston, TX
Aug 12, 2008
  • Aug 12, 2008
I have a 65 coupe that I am converting my single master cylinder to a dual. I have a new distribution block as well as an adjustable proportioning valve. I wanted to verify I had everything correct before I began installing it all. Please let me know if the illustration I drew has the right routing of the lines. Thanks.
dennis112
1,561
36
79
Amish Wonderland of Central PA.
Aug 12, 2008
  • Aug 12, 2008
Looks great--routed just like I did mine.
I assume that you have disc brakes based upon the size of the rear reservoir and your use of a proportioning valve? Drum brakes will not require either.
BarnStang
1,260
Hagerstown, MD
Aug 12, 2008
  • Aug 12, 2008
You may want to consider a 10lb residual valve after the porportioning valve, but before the rear brake dist block on the rear end housing. THis will keep 10lbs of pressur on the rear drum brakes so they don't retract all the way. Keeps the pedel travel short. I put mine right where the hard line goes to the flex hose at the back of the rear floor boards. Oh! there was a great thread awhile back about master cylinders having/not having built in residual valves. Make sure what your MC is if you decide to add one.
Rusty67
20+ Year Stangneter
Dec 3, 2002
3,749
37
109
LA, CA
Aug 13, 2008
  • Aug 13, 2008
Not having a 10 PSI residual pressure valve in the drum circuit will cause problems unless the MC is mounted below the drums.
I don't know for sure but I don't think having 2 of them in the same circuit will cause any problems. Not having it WILL cause problems.
R
Fox Hydroboost conversion/proportional valve
  • RubyRedNotch
  • Jul 20, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 20, 2026
RubyRedNotch
R
68 manual disc/drum master cylinder
  • Butchd88
  • May 27, 2026
1965 - 1973 Classic Mustangs -General/Talk- May 27, 2026
Butchd88
Brakes FOX BRAKES ISSUES
  • PonyGTrider
  • Jan 11, 2026
  • 2 3
2K
Fox 5.0 Mustang Tech Jan 31, 2026
Mustang5L5
Weber Carburetor tuning help
  • SchwarzStock
  • Jul 6, 2026
1965 - 1973 Classic Mustangs -General/Talk- Jul 19, 2026
SchwarzStock
How to Route Subframe-Style Intermediate Brake Line?
  • cnorman31
  • Nov 29, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Nov 29, 2025
cnorman31
