  • 1994 - 1995 Specific Tech
brake problem
  • Thread starter Thread starter clang5oh
  • Start date Start date May 22, 2004
clang5oh
254
in a car that scares women and children
May 22, 2004
  • May 22, 2004
ok so i put on new calipers pads and rotors up front. nothing fancy just factory replacement but i have a mushy brake peddle. i have bled and bled the brake system, front and back. i cannot get a good solid peddle. any ideas.
mo_dingo
20+ Year Stangneter
Aug 26, 2003
3,031
Tucson, AZ
May 22, 2004
  • May 22, 2004
Is your brake light on, even when the E-brake is fully disengaged?
If it's not on, then my guess is something to do with your brake master solenoid. The solenoid is pretty complex; There are many things that could be going on.
But, you may not need the entire solenoid assembley replaced. Check the vacuum line going from the engine to the vacuum tree. It could be cracked, causing loss of the "power brake feel". Read through the haynes manual section on the master solenoid. It should give you a clue as to what is wrong.
Scott
94TURBO5 O
2,509
VA
May 23, 2004
  • May 23, 2004
Did you start with the rotor farthest from the Master Cylinder when you bled them? If you let air get into the ABS system you may have to take it to Ford. Did your MC resivoir go dry/empty?
W
Front ATS brakes with Taurus rear brakes. Full parts needed?
  • Wagonized
  • Sep 24, 2026
Fox 5.0 Mustang Tech Sep 25, 2026
General karthief
Front brakes not releasing
  • Boats90GT
  • Sep 15, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 25, 2026
Boats90GT
Brake pad and rotor upgrade
  • Sparky714
  • Aug 7, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 17, 2026
Sparky714
G
Auto City Classics 67-70 Mustang disc brake kit question/s
  • GOvert
  • Jun 30, 2026
1965 - 1973 Classic Mustangs -General/Talk- Jun 30, 2026
GOvert
G
H
Strange steering/brake issue
  • Haxmaster
  • Jun 2, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Jun 3, 2026
squeak93
