  • SN95 4.6L Mustang Tech
Brake problems
  • Thread starter Thread starter Sanco213
  • Start date Start date Apr 11, 2010
Sanco213
23
  • Apr 11, 2010
so after stainless steel brake line install. after bleeding my brakes the front calipers wont unlock..help me please any ideas??
M
mr-mike
122
  • Apr 11, 2010
when installing new caliper its better to open the bleeder & just let it drip natuaraly till you see the fluid start to drip ..... unless there is a defect they should move unless there us air trapped plus the anti-lock play a part in the bleeding part depending on what year
Sanco213
23
  • Apr 11, 2010
its a 2003. i have bled the brakes alot! the rear are fine. its just the front.. idk..
M
mr-mike
122
  • Apr 11, 2010
I have a 99 it once gave me trouble after a complete brake job I used a vacume to suck out all the fluid had my son filling the master cyl ...... also my 99 has bleeders on the master cyl you must start on the far away rear & work towards the front sounds like vacume block get a buddy & use the vacume tube to watch intill all the fluid is clean & air free ....... could be incorrect lines or calipers may be bound up or defective ? start it tomorrow another day with a friend two heads is a big help ..... good luck its fixable ...there is a valve I think its called a diverter valve it could be air bound ?
bdcardinal
tree hugger
Jun 10, 2003
3,612
santa barbara, CA
Apr 11, 2010
  • Apr 11, 2010
did the master run dry? is the car equipped with ABS?
nyuk98gt
1,427
Chesterfield, MO
Apr 11, 2010
  • Apr 11, 2010
Sanco213:
Did you bleed the master cylinder? There are a couple of bleed screws on the engine side of the m/c.
If you got air into your ABS then that might be the issue. I do not know if the '03 requires "the Ford ABS machine" to purge the air but some later model Mustangs need the machine and cannot be bled without it.
Chris
Sanco213
23
  • Apr 11, 2010
yes it does have bleeders on the master cylinder. and yes the m/c did go dry. and yes it does have ABS.
so i am going to try again. what is this ford abs machine?
Dr Jay
134
Canada
Apr 12, 2010
  • Apr 12, 2010
Subscribing, my master is dry at the moment, going to finish up my brake job in the next week or two......sorry I can't help yet, hope you get this figured out. Have you tried bleeding the master yet?
nyuk98gt
1,427
Chesterfield, MO
Apr 12, 2010
  • Apr 12, 2010
Gents:
Pardon me, I posted CRAP info about the ABS requiring a special machine. What I was referring to was the NGS Star Tester device needed to review and clear ABS system codes. For brake bleeding, fill up the m/c and bleed as normally done, finishing with the two bleed screws on the m/c.
Here is an excellent link (imho) that gives you GOOD INFO about bleeding brakes and the ABS system.
http://www [take the space out to make the link work] .veryuseful.com/mustang/tech/brakes/bleeding.html
Chris
Dr Jay
134
Canada
Apr 13, 2010
#10
  • Apr 13, 2010
  • #10
Good info there, thanks Chris. As for the OP, would like to know if this has helped solve the issue
Sanco213
23
#11
  • Apr 15, 2010
  • #11
yes i have bled the master.. i get no air bubbles at all out of the brake system. from reasearch and calling ford, if i did by some chance get air into the ABS block, then it could be trapped. and if so the only way to get i tout is too cycle the abs with a scan tool that has an ABS brake bleed option. ford wants $100.00 to do it, but getting the car their is another issue. i don't think that my calipers could of gone bad just from sitting for a lil while, but idk. i think i may just buy one caliper and bleed it out just to be sure if it is the calipers or if i have to get the car to ford.
Dr Jay
134
Canada
Apr 15, 2010
#12
  • Apr 15, 2010
  • #12
Found this on the ford-trucks forums under bleeding abs.....
If equipped with the 4 wheel anti-lock brake system and the Hydraulic Control Unit (HCU) has been replaced or is suspected of containing trapped air; bleed the brake system using the procedure below. Conventional brake system bleeding cannot remove the air trapped in the lower portion of the HCU. If a spongy brake pedal is present and air in the hydraulic control unit is suspected, use the following procedure:
1. Bleed the brake system as outlined in the conventional bleeding procedure.
2. Connect a New Generation Star (NGS) tester or equivalent scan tool, to the serial data link connector below the instrument panel as though retrieving codes.
3. Make sure the ignition switch is in the RUN position.
4. Follow the instructions on the NGS screen. Verify correct vehicle and model year go to the "Diagnostic Data Link' menu item, choose ABS Module, choose "Function Tests", and choose "Service Bleed."
5. Bleed the right-front wheel as follows:
---A. Open the caliper bleed screw and pump the brake pedal for 3 seconds. Repeat the procedure again.
---B. When the fluid runs clear, begin the program and continue to pump the brake pedal.
---C. Continue bleeding for approximately 1 to 2 minutes after the program ends and then tighten the bleed screw.
6. Repeat the bleeding procedure to the left-front, left-rear and finally the right-rear wheel.
7. Remove the pressure bleeding device and adjust the brake fluid level.
8. Road test the vehicle and check for proper brake system operation.
W
Front ATS brakes with Taurus rear brakes. Full parts needed?
  • Wagonized
  • Sep 24, 2026
Fox 5.0 Mustang Tech Sep 25, 2026
General karthief
H
Strange steering/brake issue
  • Haxmaster
  • Jun 2, 2026
SN95 4.6L Mustang Tech Jun 3, 2026
squeak93
2000 GT-Front Brakes Not Releasing
  • stormsedge
  • Aug 7, 2026
1996 - 2004 SN95 Mustang -General/Talk- Aug 7, 2026
Bronco2fan
2003-04 Mustang Cobra Brake Conversion
  • Cassiebaebae
  • Oct 8, 2026
1996 - 2004 SN95 Mustang -General/Talk- Oct 9, 2026
Cassiebaebae
Front brakes not releasing
  • Boats90GT
  • Sep 15, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 16, 2026
AeroCoupe
