brake question.
The brake drum will be effective for braking longer than it will be safe. The adjustments in the brake pads do that. At some point, however, the walls of the drum become too thin and weak. It should be cast or stamped into the drum. When you take them off and have them turned the shop should measure them for you and let you know if they can be turned safely.
