brake question
  • Thread starter Thread starter rbohm
  • Start date Start date Aug 2, 2007
rbohm
6,698
550
204
tucson,az
Aug 2, 2007
  • Aug 2, 2007
recognizing that balance front to rear is important, i am considering putting together an interesting brake combination.
use 69 lincoln four piston calipers in front with 12" rotors,
65-67 mustang four piston calipers with 11" rotors in the rear,
and using a master cylinder with a 1 1/8" bore. yes i will be using a power brake booster.
how about it guys, think this will be a decently balanced system?
65 fastback
1,347
Northern VA
Aug 2, 2007
  • Aug 2, 2007
What rear end will you be using?
You don't want to run fixed calipers in the back if your rear axles are retained by "C" clips. Axles with C-clips tend to have side to side movement. This can cause pad kick back - since the caliper is fixed, if the axle moves outward it forces the pad of the fixed caliper back, the pistons get pushed back into their cylinder boars and you basically loose the rear brakes. You can regain them by pumping the pedal, but it's not a good set up.
If your running an 8" rear, you need to use a single piston floating caliper for your rear brakes. A floating caliper can move with the axle movement.
The Ford 9" does not use a C-clip, so a 4-piston fixed caliper would work, but it is basically overkill for the rear brakes.
Tim
69gmachine
576
Southern Maryland
Aug 2, 2007
  • Aug 2, 2007
I think the front 4 piston calipers on the rear will displace too much volume. You won't find a MC with enough stroke. The rotor diameters look fine. Assuming you put smaller calipers on the rear, I think you will be fine for most situations, but in a panic stop you're probably gonna crash into the guy in front of you because you won't be able to generate enough force to haul your car down from speed. That's exactly why I just swapped out a 1 1/8" to a 1" MC. Maybe your car weighs a lot less than mine though and it won't be an issue. The calipers you mention weigh a ton. Why not use something in aluminum?
rbohm
6,698
550
204
tucson,az
Aug 2, 2007
  • Aug 2, 2007
tim you are mixing an 8" with an 8.8" rear. i am using an 8" rear.
69, i was thinking the same thing regarding the m/c. cobra automotive recommends using the 1 1/8" bore master with their lincoln caliper kit. the lincoln calipers do have larger pistons than the 65-67 four piston calipers do.
65 fastback
1,347
Northern VA
Aug 3, 2007
  • Aug 3, 2007
I may be, I know the 8.8" uses C-clips to retain the axles. I, also, thought the 8" used C-clips.
Tim
rbohm
6,698
550
204
tucson,az
Aug 3, 2007
  • Aug 3, 2007
the 8" is like its larger brother the 9".
mustangmike6996
5 Year Member
Nov 10, 2005
483
clinton twp, MI
Aug 3, 2007
  • Aug 3, 2007
any rear end with a removable third member (center carrier and pinion gears) has to use the setup where the axle is bolted in behind the drum.... like the 9"... the 8.8" is an Integeral rear end which use c clip retainer like the 10 and 12 bolt gm axles and have the removable carrier cover
G
Auto City Classics 67-70 Mustang disc brake kit question/s
  • GOvert
  • Jun 30, 2026
1965 - 1973 Classic Mustangs -General/Talk- Jun 30, 2026
GOvert
G
J
  • JasonB66
  • Jul 23, 2026
  • Suspension
Suspension Jul 23, 2026
JasonB66
J
87 lx 4cyl to v8 project 4 lug disc conversion questions
  • 87lx428
  • Mar 24, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 25, 2026
87lx428
Brakes Brake caliper ID help
  • kidott
  • Sep 2, 2025
Fox 5.0 Mustang Tech Sep 2, 2025
AeroCoupe
H
Strange steering/brake issue
  • Haxmaster
  • Jun 2, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Jun 3, 2026
squeak93
