Brakes are DONE!!!!!!YAYYYYY!!
old_blue
1,783
282
124
Well, as some of you know I have had the worst time bleeding my brakes after my 5 lug conversion. today for the first time I took it for a ride around the block and the brakes work perfectly.
The problem I was having was I would turn my car on and sit in the garage and step on the pedal. I would pump it a few times then start pushing hard and the pedal would eventual bottom out. Well I decided I would take it on the street and see what happened. The pedal never bottomed out. The car stopped way before the pedal came close to bottoming out and when I slammed on it the brakes locked up nicely. This is all just around the block kinda stuff because I need to get it aligned before I do any freeway testing.
Special thanks to Shakerhood, you hung in there with me and all my fustrations.
Here is one when I very first finished it. since some will ask
front
245/45/17
rear
255/45/17
oops 255/45/17 sorry bout that I did have 255/40/17 but they looked weird with the 45's up front. for some reason it looks like the rear is way high in that picture. I don't know why.
edit:fixed
haha, Bout all I can do since it doesn't go that fast right now. Holley systemax will be here next year with an explorer intake as well as a 65 tb. I need to talk to tmoss about polishing the intake though. He said it didn't need to be done with thumpers but I don't know with these heads.
ryan might be referring to me needing a paint job. of course he is right. not aint going to happen until I get the engine and interior better off. all go no show LOL
Dude I am thrilled to hear that your car is all better now, it kinda helps put the frustrations behind you when you get to the end result!
thanks flavadave4
stykthyn said:
did you have to replace the brake booster and the master cylinder or were you able to use the 4 cyl parts?
I had an 89 gt I bought for $800 that I later found out had a bad title and couldn't register it (no wonder so cheap huh?) So I just swapped everything into a 4cyl LX I bought for $200. Both cars were completely stripped and them reassembled.
now I have a 93 cobra booster with a sn95 m/c. works well. The brakes were pretty much done a week ago after I bled it for the 100th time. I just never took it out to test it. I just decided to take it out on the road and the brakes are perfect. I love it. Now I am just looking for some C/C plates so I can get it aligned. I found some steedas for $149 and some MM's for $169. can anyone justify the extra $20??? if not then I will just go with steedas. It si a street car so I won't be readjusting it but if MM's are that much better then I will snag a set.
grey5.0beast said:
Thatwas when it was first done, read ryan.
From now on, I want you to read every post twince before you comment on it :D
Awesome man, get some vids of it...stopping lol
i know Jon, i saw his first thread a while ago about just getting it done. just messing with him, i dont think it worked :bs:
