Brakes too soft..
  • Thread starter Thread starter Blakthorn
  • Start date Start date Jun 23, 2005
Blakthorn
299
US
Jun 23, 2005
  • Jun 23, 2005
Car was in body shop for about 3 weeks....they didn't touch anything except the body so now Im confused as to why my brakes suck so bad.
I literally have to put the brake to the floor to stop the car from rolling, even if its pushed to the ground it still slowly inches up, its not the pads so whats causing this problem??
Also the convertible top is having tons of trouble making it up when I push the button, it goes half way and starts straining, is it a battery problem or a top motor?
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Jun 23, 2005
  • Jun 23, 2005
Bleed the brakes & if that doesn't fix it, replace the master cylinder.
srothfuss
Last night I stabbed the same guy 7 times in a row
Oct 17, 2004
1,796
Woodward Ave.
Jun 23, 2005
  • Jun 23, 2005
For the top, you can check to see if the cylinders are filled with fluid. It's a hydraulic system and if your runnig low on fluid, then the top will not function properly.
Blakthorn
299
US
Jun 23, 2005
  • Jun 23, 2005
srothfuss, where is the cylinder to check
ss93cobra
1,422
Wilmington NC
Jun 23, 2005
  • Jun 23, 2005
Regarding the cylinders, open your trunk and in the front part of the cargo area is the top motor. Follow the hydraulic lines to each side to locate the cylinders in question. Regarding the brakes, what portion of the car did the body shop work on? If they were under the hood (hood itself, fenders, etc) then perhaps the booster vac. line got knocked off. Perhaps I'd check the obvious vs. throwing on a new master cylinder, it sounds too much like a huge coincedence if you know what I mean...
Blakthorn
299
US
Jun 23, 2005
  • Jun 23, 2005
ss93 they just did body work, nothing under hood, front bumper, luggage rack off and spoiler and rear cobra bumper
i dont know where to start to check because it was fine when I left it, now the pedal is way to mushy..
ss93cobra
1,422
Wilmington NC
Jun 23, 2005
  • Jun 23, 2005
How's the fluid level then? Have you had the chance to check for a leak yet? Without them being under the hood, it seems awfully strange that the problem would arise now. I can't help but think it has something to do with what they've done.....
Blakthorn
299
US
Jun 23, 2005
  • Jun 23, 2005
well the fluid is in between Min and Max, where it should be
I havent bled the brakes in over a year (could that be the problem?)
ss93cobra
1,422
Wilmington NC
Jun 23, 2005
  • Jun 23, 2005
Only if air has somehow gotten into the system...
mrswivlepants
93
#10
  • Jun 23, 2005
  • #10
You confident in this bodyshop? I only ask because I work at a dealership with an independent bodyshop renting space out back. These guys will do anything to get a part to make a nice fit and finish. Sometimes they tear out the entire front suspension when they really have to get in there and do some custom adjustments and fabrication.
Blakthorn
299
US
Jun 23, 2005
#11
  • Jun 23, 2005
  • #11
the body shop was recomended by a friend, i dont think they went all out for my car...i think they just wanted the job done =\
2000 GT-Front Brakes Not Releasing
  • stormsedge
  • Aug 7, 2026
1996 - 2004 SN95 Mustang -General/Talk- Aug 7, 2026
Bronco2fan
H
Strange steering/brake issue
  • Haxmaster
  • Jun 2, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Jun 3, 2026
squeak93
D
Brakes 88 LX 5.0 - help! no brakes
  • DRGunn427
  • Feb 26, 2025
Fox 5.0 Mustang Tech Feb 27, 2025
nickyb
Drivetrain 83’ Glx convertible C5 Trans help!
  • JacksonJared2113
  • Dec 25, 2025
Fox 5.0 Mustang Tech Dec 26, 2025
JacksonJared2113
M
Engine Unexplainable Exhaust Pop and Gurgle
  • Mrnissen122
  • Feb 14, 2026
Fox 5.0 Mustang Tech Feb 18, 2026
