brakes
  • Thread starter Thread starter Daniels1414
  • Start date Start date Apr 25, 2006
D
Daniels1414
31
St. Louis
Apr 25, 2006
  • Apr 25, 2006
I know this has been talked about alot but I ned a brake upgrade. I currently have drums and need to upgrade to discs. I ave 15" wheels so that kindoff limits my choices. I think I've limited my options to Baer, SSBC, or Willwood. I'm leaning toward the SSBC right now but they are alot of $. Also need a new MC. Any suggestions would be appreciated. Thanks
Pbum5
515
Minneapolis, MN
Apr 25, 2006
  • Apr 25, 2006
There are many options out there.
On my 67, I went with a 68 Style disk in the front with upgraded parts like cross-drilled and slotted rotors and semi metallic pads. I went with SSBC in the back.
Here is the write up and pics of what I did.
http://forums.stangnet.com/showthread.php?t=536542&highlight=projects+begin
If you do a search you can find a lot of info on disc swaps.
J
John Z
581
Morgantown WV
Apr 26, 2006
  • Apr 26, 2006
There are kits that allow you to bolt caliper brackets to your existing spindles and add rotors w/o changing the track width of the wheels. Since these are bolt on units, you do not even need to get the car realigned after the install. Two sources are rod and custom motor sports and Scarebird. IIRC you can do the Scarebird swap, including new mc, proportioning valve, calipers, rotors and hoses for just over $300. When the time comes I'll probably go with Scarebird. http://www.scarebird.com/12802/19004.html
I've heard on other discussion groups that his product is better than his web page.
HTH
LMan
1,246
Mom's basement
Apr 26, 2006
  • Apr 26, 2006
www.discbrakeswap.com
yeah, another one for me!
degins
361
Texas
Apr 28, 2006
  • Apr 28, 2006
LMan,
Thanks for your support. Just thought I'd let you be the first to know that I have completed the engineering work on a Granada style spindle/bracket set that has geometry that is correct for 65-66 Mustang. This set will allow 65-65 owners to maintain stock steering and suspension geometry and upgrade to the beefier spindle with the large diameter axle pin/bearing set while doing a front disc brake swap. This swap will not affect bumpsteer. They will be in production soon.
G
grego37
576
Fresno CA
Apr 28, 2006
  • Apr 28, 2006
If you can wait a little longer, Im about to upgrade my brakes and will be selling or Ebaying:
Complete Factory front disc brake set up from a 68 Mustang, with rebuilt calipers, new bearings and new rotors (under 200 miles or wear on the "new" parts. complete with spindles and all , assembled.
Let me know if you're interested
rbohm
6,698
550
204
tucson,az
Apr 29, 2006
  • Apr 29, 2006
if you are interested in performance brakes that fit 15" wheels, check cobra automotive. they have a 12" front brake kit that uses 4 piston 69 lincoln calipers. you can also get their rear drum kit that uses 11x2 1/4" shoes. they use this very settup on the vintage race cars where factory parts, or factory size(the 68 tbird had 12" rotors with a 5x4.5 wheel bolt pattern, and they fit the 65-69 v8 spindles) parts are required, and they work very well. i think they cost less than baer brakes also.
DukeGnarley
597
Auburn/Ellensburg, Wa
Apr 29, 2006
  • Apr 29, 2006
I ordered some baer brakes for my new rear end about four weeks ago, and i just heard from baer that it's going to be another 4-5 weeks before i get them :-(. I do have the fronts installed though. very easy install, but i haven't driven with them yet. before you buy a new mc, make sure that whatever you go with doesn't already come with one.
bnickel
5,640
lubbock, texas
Apr 29, 2006
  • Apr 29, 2006
degins said:
LMan,
desgins, i don't suppose you've given any more thought to doing a lowering spindle with a raised pin location have you? i'd like to have a spindle like that and would be a great performance improvement
A
Help Needed! 2012 S197 brake caliper dimensions
  • AussieDavid
  • Mar 28, 2026
2005 - 2014 S-197 Mustang -General/Talk- Mar 28, 2026
AussieDavid
A
Which SN95 axles for 93 LX, disc brakes, ABS rings?
  • dan50
  • Mar 22, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 3, 2026
7-UP BILL
J
  • JasonB66
  • Jul 23, 2026
  • Suspension
Suspension Jul 23, 2026
JasonB66
J
I
Engine Help requested in identifying how to resolve engine light issue
  • Ianslaney
  • Oct 4, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Oct 4, 2026
Bullitt347
D
Brakes 1966 Mustang convertible 289, Auto - Disc brake conversion issues
  • DRGunn427
  • Feb 26, 2025
Classic Mustang Specific Tech Jul 23, 2026
All Stock93
