brakes
  • Thread starter Thread starter Graydon5oh
  • Start date Start date May 20, 2007
Graydon5oh
215
ARKANSAS
May 20, 2007
  • May 20, 2007
ok still having bake problems new master cylinder brake cylinders calipers are good and lines are good new distribution block brake lines are good and can not find a leak. when i hit the brakes the seem good then slowly leak to the floor. causing me to have to pump the brakes the line to the booster is getting vacuum. my friend told me that it may be my brake booster but i thought if it went bad it would just cause me to have manual brakes and them just be really firm and hard to push any ideas would help please
T
Trefty
117
  • May 20, 2007
Well youve definitely got air in your system. Re-bleed the brakes and check again. A leaky power brake booster wont cause your pedal to be spongy but will make it harder for you to apply the brakes.
W
wrenchbender
12
Lenexa, Ks.
May 20, 2007
  • May 20, 2007
Sounds like you have a defective master cylinder.
Aryan15
236
CA
May 20, 2007
  • May 20, 2007
make sure to start from the farthest brake from the master cyl. and work your way to the closest.
cjones
1,561
Avondale, AZ
May 20, 2007
  • May 20, 2007
did you fully bleed the master before you installed it. if so, and you bled the brakes of air then i'd return the master.
T
Trefty
117
  • May 20, 2007
Yea, make sure the master cylinder was bench bled before installation.
SVT32VDOHC
waiting for the next hack atta
3,501
28
119
Motor City
May 21, 2007
  • May 21, 2007
Sounds like a bad booster to me. Some get rusty and they leak where the master butts up with booster. You may not see rust holes, but they oculd be there!
Brakes FOX BRAKES ISSUES
  • PonyGTrider
  • Jan 11, 2026
  • 2 3
2K
Fox 5.0 Mustang Tech Jan 31, 2026
Mustang5L5
68 manual disc/drum master cylinder
  • Butchd88
  • May 27, 2026
1965 - 1973 Classic Mustangs -General/Talk- May 27, 2026
Butchd88
87 lx 4cyl to v8 project 4 lug disc conversion questions
  • 87lx428
  • Mar 24, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 25, 2026
87lx428
D
Brakes 88 LX 5.0 - help! no brakes
  • DRGunn427
  • Feb 26, 2025
Fox 5.0 Mustang Tech Feb 27, 2025
nickyb
Manual disc brakes
  • Butchd88
  • Feb 28, 2026
1965 - 1973 Classic Mustangs -General/Talk- Mar 27, 2026
zookeeper
