braking issue
  • Thread starter Thread starter skywalker
  • Start date Start date Aug 20, 2004
1 of 2 Next Last
skywalker
733
Pensacola, FL
Aug 20, 2004
  • Aug 20, 2004
Okay, I've had this problem since day one with my brakes.
When I go to stop I have to "pump" the brakes to get good strong pedal feel when braking.
I originally had drums and the problem continued after my disk brake conversion. I've replaced most of my brake lines, have no apparent leaks and a new master cylinder. I've bled the living piss (figuratively) out of the brakes. I did a bench bleed on the master cylinder when I installed it.
what the heck is going on?
D
dj747
  • Aug 20, 2004
I had a similar problem and it turned out to be the power brake booster. I can't figure out why pumping had an effect, but it fixed mine. Time for a new vacuum booster?
Good luck
Dan
skywalker
733
Pensacola, FL
Aug 20, 2004
  • Aug 20, 2004
manual brakes. So booster is ruled out.
O
Ozsum2
695
  • Aug 20, 2004
new lines, new MC, gotta still be air in the lines or it is getting in there from an un-sealed breeder screw.
skywalker
733
Pensacola, FL
Aug 20, 2004
  • Aug 20, 2004
I'll double check that (in fact I think I'm goint to get some speed bleeders) but I swear, I've done everything I could to prevent that. I actually snapped a bleeder screw in half tightening them down.
Cdaniel
220
Arizona
Aug 20, 2004
  • Aug 20, 2004
Do you still have rear drums? Could be out of adjustment, worn linings or drums turned out to much. Or a combo thereof.
Cdaniel
220
Arizona
Aug 20, 2004
  • Aug 20, 2004
Nevermind, I just noticed the 4 wheel discs in your sig line.
WORTH
20+ Year Stangneter
Nov 18, 2002
2,166
44
98
Cape Cod, Ma.
Aug 20, 2004
  • Aug 20, 2004
IF it's 4 wheel disc , does it have a master capable of filling the rear calipers or is it a drum rear master? Calipers take more fluid than wheel cylinders
O
Ozsum2
695
  • Aug 20, 2004
"breeder screws?" I really need to start proof reading.
skywalker
733
Pensacola, FL
Aug 20, 2004
#10
  • Aug 20, 2004
  • #10
Don't worry, I do it too. It is a sign of superior intelligence.
I'm not sure if my master cylinder is big enough indeed (anyone want to suggest a good one for 4 wheel discs?) but I had this same problem with 3 wheel drums.
I was looking at a couple of wilwood aluminum ones but none seem that they will easily bolt up.
O
Ozsum2
695
#11
  • Aug 20, 2004
  • #11
Yea, since you had it B4, I'm thinking it isn't a parts compatibility problem, but a mechanical gremlin thing.
skywalker
733
Pensacola, FL
Aug 20, 2004
#12
  • Aug 20, 2004
  • #12
Yes and it's pretty bad too, sometimes the car will barely get brake pressure upon initially pressing the brakes. Not something I'm happy with.
WORTH
20+ Year Stangneter
Nov 18, 2002
2,166
44
98
Cape Cod, Ma.
Aug 20, 2004
#13
  • Aug 20, 2004
  • #13
IF you had it before it could have just been the brakes out of adjustment
if you have to pump more than once to get the piston to reach the caliper, either the piston is too far away from the caliper or the master is not putting out enough fluid to push it far enough.
If you have air in the system, you'll always have a spongy pedal regardless of how many times you pump it, because air compresses.
monk302
742
New Jersey
Aug 20, 2004
#14
  • Aug 20, 2004
  • #14
I was having a similar problem with mine and what had happened was I put the calipers on the wrong side. I switched them and it was fine. I still cannot believe I put them on the wrong side. Oh well, I can put someone through the windshield now.
O
Ozsum2
695
#15
  • Aug 20, 2004
  • #15
Then you'd have air brakes.
68GEETEE
5 Year Member
Nov 21, 2003
481
Texas, USA
Aug 20, 2004
#16
  • Aug 20, 2004
  • #16
What MONK said is what happened to me too. Someone had installed the right caliper on the left wheel, and vice-versa, so the bleeders were positioned at 4 oclock instead of 12 oclock. . You can bleed them all day long, lots of fluid comes out, but the air is trapped in a pocket ABOVE the bleeder screw. . NO pedal. . I reinstalled them correctly, bled them and I have great brakes.
Note, the bleeder has to be at 12oclock position, when it is corrrect, the screw itself will most likely point to the rear of the car.
skywalker
733
Pensacola, FL
Aug 20, 2004
#17
  • Aug 20, 2004
  • #17
Only one problem with that: I have wilwoods in front which can go on either side and my rears are from a newer ford and they're on correctly. The pedal is spongy at all times...but to feel any pressure at all in the pedal, I have to pump it up. Oh well, maybe I'll try doing a vacuum pump bleed tomorrow.
No one has yet to suggest a good master cylnder for 4 wheel discs.
Cdaniel
220
Arizona
Aug 21, 2004
#18
  • Aug 21, 2004
  • #18
Maybe your master cylinder needs those residual pressure check valves?
67coupestang
509
#19
  • Aug 21, 2004
  • #19
I recomend one from a 98ish explorer. Its aluminum bodied, with the plastic res, I think its a 1 1/8" bore and the ports are on the outside, not facing the engine.. It will have a weird switch but just leave it unhooked. best of all about $25 in a yard.
skywalker
733
Pensacola, FL
Aug 21, 2004
#20
  • Aug 21, 2004
  • #20
finding a junkyard with an explorer might be an issue for me. So I might have to buy new, with this in mind does anyone have any suggestions? Aftermarket even?
1 of 2 Next Last
Fox Brake pedal too stiff
  • keel
  • Sep 21, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Thursday at 12:24 AM
Shakerhood
2000 GT-Front Brakes Not Releasing
  • stormsedge
  • Aug 7, 2026
1996 - 2004 SN95 Mustang -General/Talk- Aug 7, 2026
Bronco2fan
O
1967 Manual Drum Brakes , replaced the master cylinder and the brake light switch but the brakes lights stay on.
  • OldNSloww
  • Jul 14, 2025
Classic Mustang Specific Tech Jul 16, 2025
horse sence
Brakes Foxbody Brakes still soft
  • 86posmustang
  • Nov 5, 2025
Fox 5.0 Mustang Tech Dec 3, 2025
nicholase
G
66’ drum bleeding
  • Geno66
  • Sep 1, 2025
Classic Mustang Specific Tech Sep 8, 2025
GOvert
G
