Breaking in a new cam - what oil?
  • Thread starter Thread starter fasttback
  • Start date Start date Oct 22, 2006
fasttback
471
Northern CA
Oct 22, 2006
  • Oct 22, 2006
I will be installing a new hydraulic flat tappet cam very soon. My question: could I use the existing 10W-30 synthetic oil in the motor now (4 months old/weekend driving) or should I change it for some dino 30 weight?
Of course, I will change it again after the break-in period for the cam.
brin0357
169
  • Oct 23, 2006
Non synthetic, zinc rich oil will be fine. Replace with your oil of choice after break in.
GoinBroke
109
Joliet, Il
Oct 23, 2006
  • Oct 23, 2006
Just as brin stated you need a oil rich in Zinc and Phosphate. I broke my engine in last week and used Rotella T diesel along with a shot Comp Cams engine breakin lube. You can also go to you local GM parts deptartment and buy their GM engine oil supplement. Good luck! Do some research on how to break it in during the initial startup.
O
Oldskool
25
  • Oct 23, 2006
I just broke in an aggressive high-lift flat tappet solid lifter cam without any problems using Shell Rotella T 15W 40 "dino" oil. It's made for diesel engines and already has the extra additives you need for initial break-in.
Swede958
712
Austin, TX
Oct 24, 2006
  • Oct 24, 2006
+1 for diesel oil... most old schoolers say use 30wt for break in
fasttback
471
Northern CA
Oct 24, 2006
  • Oct 24, 2006
Sounds good. Are these zinc rich oils (e.g. Shell Rotella) found at most auto stores (PepBoys, AutoZone, Kragen, Napa)?
D
D.Hearne
11,730
south louisiana
Oct 24, 2006
  • Oct 24, 2006
In addition to the oil, you also need to make certain the new lifters spin freely in their bores when you install them. Do NOT slather the cam lobes and lifters with too much assembly lube. A thin film on both the lifter bottoms and the lobes is all that's necessary. Too much lube is as bad as not enough. Too slippery and the cam lobe may not get enough grip on the lifter bottom to set it in motion, spinning in their bores. No spin and you WILL lose a lobe.
Oil choice for after break in period.
  • Sask84gt
  • Feb 28, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 14, 2026
Praetorious
P
H
Ongoing Battle With Hydraulic Lifters
  • hailer06
  • Jun 8, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 9, 2026
  • 68_Disgustang
  • Feb 22, 2026
1965 - 1973 Classic Mustangs -General/Talk- Jun 20, 2026
gray owl
G
A
2001 Mustang GT, scorched metal smell and noise from trans/diff?
  • AndyE2255
  • Dec 1, 2025
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Dec 28, 2025
gkomo
R
  • riored97snake
  • Jun 18, 2026
  • What is it Worth?!?!?
riored97snake
R
