Brighter headlights without HID
Loco5.0 said:
My silverstars are not yellow like yours in the pic. :notnice: Sure they're silverstars?
Here's a pic of my Silverstars without an upgraded harness.
Now we have a comparison. :spot:
:stupid:
That ain't no comparison. :lol: :rlaugh: :lol: :rlaugh:
Comparison is when you use the same context with 2 different variables. Hence, you should have a side by side, headlamp by headlamp comparison. :bang:
Loco5.0 - You lose...
Nice job Blackcloud...you did it the RIGHT way...:nice: Good stuff:) Some are just jealous:p
Can you give a link to which harness you got?
I'm with you Nick;) (Stang8URIMPORT)
Only thing is I haven't verified long term affects (if any) on any possible damage to the headlight housings from the extra heat generated by the bulb. I only drove for 30 minutes with them installed and all was OK at that time. I will keep you guys updated.
That can be a potential issue - I think I alluded to it earlier. My headlights are all steel and glass - not an issue for me. Y'all are in a different situation with your headlights - pay close attention. Some of the higher wattage bulbs can put out a tremendous amount of heat.
1993SSP said:
im curious to which harness you got too! The only ford harness i see is 95 bucks
It's the 9004 harness and it's $55. It's the second harness pictured. It's the universal harness.
You are looking at the "dual battery super heavy duty harness" which is the incorrect one.
Here's a writeup I got a while ago from Blakthorn,
1988 FORD Mustang
High & low beam headlamp
9004
9004ST Silverstar High Performance Halogen Upgrade: The Look of HID: Whitest, Brightest
9004XV XtraVision Halogen Upgrade: Up to 20% Brighter
9004CB Cool Blue Halogen Upgrade: White Hot; Super Cool; 100% Street Legal
9004LL Long Life Halogen Upgrade: Lasts two and a half times longer
Parking light
1157A
1157AST Silverstar Signal Lighting: Complete the Look: Crisp, Clean, Style
1157ALL Long Life Upgrade: Up to twice the life of the standard lamp
Front turn signal
1157A
Rear turn signal
1156
1156LL Long Life Upgrade: Up to twice the life of the standard lamp
3157
3157LL Long Life Upgrade: Up to twice the life of the standard lamp
Tail light
3157
Stop light
3157
High mount stop light
912
921
921LL Long Life Upgrade: Up to twice the life of the standard lamp
Fog/Driving light
H3-55W
H3ST Silverstar High Performance Halogen Upgrade: The Look of HID: Whitest, Brightest
License plate
168
Back up light
3156
3156LL Long Life Upgrade: Up to twice the life of the standard lamp
Front sidemarker
916NA
Rear sidemarker
194
194LL Long Life Upgrade: Up to twice the life of the standard lamp
Ash tray
161
Glove box
1816
Map light
105
Dome light
89
906
912
Step/Courtesy light
168
194
Trunk/Cargo area
98
Under hood light
98
Instrument-general
161
1892
194
Hi-beam indicator
194
Seat belt indicator
194
Brake warning
194
Automatic transmission indicator
1816
Directional signal indicator
194
Update on heating issue
Well, I haven't driven my car too often at night since I did the hi-watt bulb upgrade but I have driven it enough to verify that the bulbs put out alot of heat....enough to start to peel or bubble the inside of the aftermarket clear housings around the socket of the bulb.
Now if one had the stock looking housings (with fluting), none of this would be apparent but with the clear housings if you take a close look you can see it. Nevertheless, I will continue to use the Silverstars which do have decent output and color so i don't totaly ruin my new housings.
