brittle vacuum lines
  • Thread starter Thread starter lmpbzkt492
  • Start date Start date Dec 16, 2006
L
lmpbzkt492
68
  • Dec 16, 2006
what do you guys suggest replacing those brittle plastic vacuum lines with. Rubber or plastic? what size line should they be replaced with?
T
TENGRAM
143
  • Dec 16, 2006
i just replaced mine with the small plastic vacuum tubing from autozone. not sure what size...small...i think they only have one size there. i used heat shrink to ensure that the seal was air tight.
JChalfan
551
Bellevue, WA
Dec 16, 2006
  • Dec 16, 2006
I've never replaced one of those lines, I just repair them when they snap. Use a peice of vacuum tube that will fit over it and connect the two broken peices.
Jeff
HISSIN50
34
129
Dec 16, 2006
  • Dec 16, 2006
You can get new bulk plastic hard line but I generally won't use it either. I do like the guys do, and use rubber line as a splice or even as a new replacement run. Either way works.
Good luck.
GearHd6
459
Ashford, CT
Dec 16, 2006
  • Dec 16, 2006
I use the hard plastic line, just heat them slightly with a hear gun to put in nice bends. Looks way cleaner than a ton of floppy slices in my opinion.
Brakes Front Brake Hardline Routing
  • 93Nifty
  • Sep 11, 2026
Fox 5.0 Mustang Tech Oct 11, 2026
limp
R
Engine Evap and charcoal cannister leak
  • ryan1994stang
  • Mar 14, 2026
Fox 5.0 Mustang Tech Mar 18, 2026
Mcmahst
P
Fuel New Eldebrock 1406 problems 1985 GT 5.0
  • Paddyman
  • Oct 22, 2026
Fox 5.0 Mustang Tech Nov 2, 2026
manicmechanic007
Engine Edelbrock 1406 install help
  • scottcarp10
  • Dec 11, 2025
Fox 5.0 Mustang Tech Dec 15, 2025
scottcarp10
Explorer intake vacuum port
  • JD1964
  • Oct 28, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 29, 2026
Mustang5L5
