Broken differential shim
  • Thread starter Thread starter cmozez
  • Start date Start date Oct 21, 2004
C
cmozez
450
Tupelo,Mississippi
Oct 21, 2004
  • Oct 21, 2004
I broke the shim while putting my trac-loc back in tonight. Any suggestions on where to get just one shim? I need one .261 but would take one bigger. I can surface grind it to size. How do you guys get the trac-loc in as tight as it is? Any tricks?
ss93cobra
1,422
Wilmington NC
Oct 21, 2004
  • Oct 21, 2004
Call your local Ford dealer and tell them you want part # D9AZ-4067-L for $12.83 and they should be able to have it in a day or two. As far as installation goes, they use a u-shaped tool with a handle on it that you can hit on the end with a hammer to drive it in.
axeman
1,348
Elizabethtown, PA
Oct 21, 2004
  • Oct 21, 2004
just go to your local ford dealer, i bet they have a bunch of shims laying around. take a dial indicator with you if possible. your shim was probably weak and that's why it broke.
the guys at my local ford dealer are pretty cool people. they let me rifle through there box of shims and even let me use their press once in a while.
C
cmozez
450
Tupelo,Mississippi
Oct 21, 2004
  • Oct 21, 2004
ss93cobra- thanks for the info. I called the local Ford dealership and gave them the part #, they had two in stock and one was the exact one that I needed. Thanks for the replys guys
ss93cobra
1,422
Wilmington NC
Oct 22, 2004
  • Oct 22, 2004
cmozez, glad I could help
D
Drivetrain Will a broken s spring affect traction?
  • dqureshi06
  • Jan 12, 2026
Fox 5.0 Mustang Tech Jan 16, 2026
Mustang5L5
Drivetrain Broken clutch cable- what it looks like
  • JulianR
  • Aug 6, 2026
Fox 5.0 Mustang Tech Aug 10, 2026
gkomo
D
Drivetrain car still rolling while in gear and off
  • dqureshi06
  • Jan 24, 2026
Fox 5.0 Mustang Tech Jan 24, 2026
General karthief
J
2004 Mustang 3.8L V6 vibrations above 65 MPH and differential leaks
  • joeybuddy96
  • Mar 16, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Aug 29, 2026
joeybuddy96
J
Eight inches is enough for me...
  • 351MooseStang
  • Nov 27, 2025
1974 - 1978 Mustang II Talk & Tech Mar 2, 2026
Bullitt347
