  • 1994 - 1995 Specific Tech
Broken Power Windows
  • Thread starter Thread starter fawcett
  • Start date Start date Aug 23, 2006
fawcett
380
Cohasset, Ma
Aug 23, 2006
  • Aug 23, 2006
So I've been waiting to go to Street Night at the NED for the longest time.
I get up there and my passanger window doesnt go up. Its been having this problem for a while but multiple clickings on the passanger side window ended up engaging it in the past. Tonight I had no luck.
I had to drive the whole way home. Two hours up and hour and a half back pissed off beyond belief.
Someone help me out and tell me what to do. What do I need?
I took the inside of the door off, aswell as the plastic protective sheet (which I guess I'll have to replace now?)
Its stuck down and I couldnt be more dissapointed with my car, what do I do?
I cant even get f-ed up because I quit drinking-this is my only stress reliever and its always breaking on me and making my life worse and taking all my money.
-fawcett
(please dont say "just do a search" cause I have but with no luck)
94GTLaserRC
Squint as you approach, lest you be blinded by my
11,178
Ernan Says "here it comes... dushbag"
Aug 23, 2006
  • Aug 23, 2006
DO A SEARCH!!!!
RIght here on the FAQ page right here:
http://forums.stangnet.com/showthread.php?t=334773
Post #4
COmmon problem with semi-easy fix.
RC
fawcett
380
Cohasset, Ma
Aug 23, 2006
  • Aug 23, 2006
So these big ass motors come out through my speaker holes?
What if my window is stuck all of the way down?
94GTLaserRC
11,178
Aug 24, 2006
  • Aug 24, 2006
You will be able to pust it up with your hands, since those pieces are broken and wont cause any resistance..GET A HELPER so the window doesnt break
RC
bigap15
115
  • Aug 24, 2006
mine does this sometimes. the way i usually get it up is to drive over a speed bump at a good speed and hold the up button on the pass side. if that dont, then u will have to do some work on the window
94-302-vert
1,947
NE CT
Aug 24, 2006
  • Aug 24, 2006
Along thos lines. hold the button and slam the door shut.. maybe that will do it.
fawcett
380
Cohasset, Ma
Aug 24, 2006
  • Aug 24, 2006
Where can I buy the plastic grommet piece? I called the local Ford dealership, they said I have to buy the whole $180 window motor assembly (and I need two).
Where to shop please help!
-fawcett
94GTLaserRC
11,178
Aug 24, 2006
  • Aug 24, 2006
-fawcett
Try Here:
http://cgi.ebay.com/ebaymotors/FORD...IT-3-KITS_W0QQitemZ130018417958QQcmdZViewItem
The technical name is "torque pins".. My Mechanic sells them for about $5. Try a private shop and ask for them.. SOmetimes they are in the HELP section in the auto stores.
RC
94GTLaserRC
11,178
Aug 24, 2006
  • Aug 24, 2006
Read this:
You will see an Email address...it's an old link, but may help
RC
http://www.automotiveforums.com/t170240.html
fawcett
380
Cohasset, Ma
Aug 24, 2006
#10
  • Aug 24, 2006
  • #10
Has anyone used the screws instead of replacing the plastic POS?
Sounds like I could do that and be done with this disaster.
EDIT: RC I tried those links, the first may work but the second is like 2yrs old (damn it)
Im pulling both motors tomorrow to see what their guts look like. Im hoping for sheered plastic bits.
I would like to know more about using the screw bits (like one of the guys running a t-bird did in your second link-he did that and said the problem was solved)
fgtmustang95
45
El Paso, Tx
Aug 24, 2006
#11
  • Aug 24, 2006
  • #11
When you have taken out the motor and opened the cover, should you be able to spin the gear freely? (clockwise or counterclockwise) I try to turn it but it turns about 1/8 of the way and stops. Is this a sign that the motors bad or would I need new bushings. My motor looks like nothing in the linked forum above. There are no chewed up pieces anywhere. Thanks fellas
HISSIN50
34
129
Aug 25, 2006
#12
  • Aug 25, 2006
  • #12
If anyone contemplates using metal in lieu of the bushings, one word of caution. The bushings are sacrificial. If you have little kids or friends that are missing chromosomes, the bushings will keep hands and fingers from getting broken if left between the window and car frame.
The OEM bushings last for 10 years or so - I'd opt to just replace them again (they will likely outlast the window motors).
Bosko5.0
1,067
longwood, FL
Aug 25, 2006
#13
  • Aug 25, 2006
  • #13
I have replaced the bushings in a 94 explorer with 3 nuts, it will work but it put more pressure on the gear and they will eventaly give, hands and fingers good bye. so went to replace mine in the Gt i got the plastic bushings,they work beutifully.
Auto zone has them in there HELP! section for like $7.49
89 power window issue
  • Creomod
  • Sep 5, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 4, 2025
WillWho?
W
T
Progress Thread 2002 Mustang 3.8L CV
  • TheIncompetentMechanic
  • May 26, 2026
1996 - 2004 SN95 Mustang -General/Talk- Jun 1, 2026
T
Can makes noises when driving poping
  • Creomod
  • Oct 14, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 19, 2025
Creomod
R
2004 convertable help
  • realbkg
  • Jun 4, 2025
1996 - 2004 SN95 Mustang -General/Talk- Jun 4, 2025
realbkg
R
E
2007 GT Stalls when lights or a/c turned on
  • ejscarfo
  • Jun 22, 2026
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech Sep 26, 2026
manicmechanic007
