Budget computer control for electric fan doesn't work
  • Thread starter Thread starter jrichker
  • Start date Start date Apr 18, 2006
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Apr 18, 2006
  • Apr 18, 2006
The title says it all: Budget computer control for electric fan doesn't work.
I tried it with an A9L & A9P computer, and it didn't work with either one. The tech note from FordFuelInjection.com, http://fordfuelinjection.com/files/A9L_E-Fan_How-to.pdf said that it worked for some but not for others. I think the number of computers it works with may be very small. I have no way of knowing what works and what doesn't other than doing their test proceedure.
I guess I'll save my $$$ for a DCControl fan controller.
vristang
4,933
101
124
Seattle
Apr 18, 2006
  • Apr 18, 2006
I thought someone had posted that they did get that to work on a A9L?
I looked and see if I can find something in my notes tonight.
It may have been on EECTuning, or the TwEECEer forum?
I was hoping this would work with my X3Z, but it doesn't look good now.
Thanks for the heads up
jason
vristang
4,933
101
124
Seattle
Apr 18, 2006
  • Apr 18, 2006
I found this thread. You may have seen it already, but others may be curious?
Clint (86GT) seems to be the pioneer of this setup. Maybe you could contact him?
http://eectuning.org/forums/viewtopic.php?t=2957&highlight=a9l+fan+control
jrichker
Mar 10, 2000
27,512
2,813
234
Dublin GA
Apr 18, 2006
  • Apr 18, 2006
Keep in mind that the computer outputs sink current (provide a ground) rather than source current. This prevents damage should the computer side wiring short to ground.
How I tested this circuit to see if it works: Since pin 41 is supposed to go to ground when the temp rises above a certain point, I did a simple test. What I did was to use a 2K ohm resistor in series with a LED. The resistor side of the LED went to pin 41 and the other side of the LED went to 12 volts. The result was that the LED was on anytime the ignition switch was on, no matter what the engine temp. What I was looking for was the LED to be off when the engine was cold and on when it was warm.
vristang
4,933
101
124
Seattle
Apr 22, 2006
  • Apr 22, 2006
I just stumbled onto this...
http://eectuning.org/forums/viewtopic.php?t=6131
It looks a little different but I didn't read it too close, maybe tomorrow.
Hope it helps.
I know you have much more electrical experience than I do, so if you can't get it to work, I'm screwed.
:Word:
jrichker
Mar 10, 2000
27,512
2,813
234
Dublin GA
Apr 22, 2006
  • Apr 22, 2006
I went through the ECCTuning site and didn't find anything more than what I already knew. Some computers work, some don't. The LED test is a simple way to find it it works or not.
  • dan50
  • Jul 18, 2026
dan50
Y
2004 Roush - Dome Lights and radio not working
  • Yurei
  • Nov 10, 2025
1996 - 2004 SN95 Mustang -General/Talk- Nov 20, 2025
squeak93
Preparation for Holley Terminator X install – Foxbody 306 (electrical fan, alternator, MSD Ignition, etc)
  • So_Flo
  • Mar 1, 2026
3K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 4, 2026
General karthief
J
2007 No Heat or AC Control
  • JonScoupe
  • Jan 18, 2025
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech Jan 25, 2025
V6 to V8 Swap info
  • 02_2v_Curtis
  • Jan 11, 2026
1996 - 2004 SN95 Mustang -General/Talk- Oct 7, 2026
2v_johnny
