JD1964 there is enough sticking out to grab on to 15 Year Member Jun 28, 2013 3,649 1,672 194 Maryland Aug 4, 2013 #1 Aug 4, 2013 #1 Would there be a build sheet put in these cars from the factory and if so, where should I look to find it?
mikestang63 SN Certified Technician Aug 27, 2012 11,606 8,859 214 In the garage Aug 4, 2013 #2 Aug 4, 2013 #2 They did away with build sheets on most production cars in the 1990 -91 when DAP switched from printed to computer build sheets so for your 92 you are SOL. You can buy a pre 1990 repro build sheet from LMRS for $10 http://www.latemodelrestoration.com/products/Mustang-Build-Sheets
GroverDill GoldMember Founding Member Aug 18, 1999 5,442 1,490 214 Demotte IN 46310 Aug 4, 2013 #3 Aug 4, 2013 #3 Mine was tucked into the rear seat bottom
