Sound deadener install
limp
wrap a little cheese around it and its a done
5 Year Member
Oct 4, 2020
5,477
2,906
173
Florida
Will be installing my carpet soon and I need to install the sound deadener matting I purchased.... Never done this before and I was looking for some advice to get me going
12 X 18 sheets.. Do I start on the transmission tunnel and work my way to both sides and back? Or can I just lay full sheets than come back and fill in? Can I overlap the material? Some of the original " tar " based sound deadener is still in a few areas.. Do I need to remove all of it or can I go over it if its not flaking off??
Did purchase a 3 pack of rollers to roll the new stuff down.....
Any advice is appreciated...
I used Dyna Mat on the Junk Pyle, after scuffing the worn areas that had surface rust, etching primer and rattle can leftovers, I started at the toe boards where the firewall insulation stopped and worked my way back to the tailinghts, full sheets first then cut and filled the rest.
Made a difference, before the carpet got really warm but after a noticeable difference, road noise was reduced also.
Reactions: limp and gkomo
Just me but I removed all of the old sound deadener. Just because it has good adhesion now doesn't mean it will later down the road and then the deadener is useless. You do not need 100% coverage. When I did the Coupe and the T-Bird I checker boarded the matting. This is what we did at the car stereo shop I worked at and it performed well and did not cost as a much.
Reactions: limp
I don't do the cover the whole car thing in it.... Only put it where sound resonates when tapping the sheet metal, doors, some areas of the pan, roof, quarters etc, the weight is what cuts out the squeaks and rattles and makes stuff feel solid vs tinny. I typical Use a lighter foam with foil backing or tape for heat and sound dampening. Foil side down if trying to block heat soak. Last time I didn't I used a cheaper line under modigt you can find on fleabay or other sites, but think prices have gone up, I grabbed em off temu, was under $50 for 25sqft of 80mil mat and 15sq feet of there 3 layer foam liner.
Reactions: limp
Its a Convertible so it will never be super quiet.. Reducing any heat would be good though... Not doing the doors, again its a vert...
Reactions: gkomo
You may need to pull up the original sound deadener. Some of mine was breaking off making it impossible to get the new stuff to stick right.
Most of it is gone, some on the tunnel in front of the shifter hole, of which I have scraped off, but there is quite a bit under the rear seat which looks like it would be a real bear to take off...
I keep forgetting to take pics and after 12 noon here its too hot to go outside...
Reactions: General karthief
