Build up
Georgie
455
Montreal, Canada
Ive been planning a bunch of things for my ride..first im doing all the suspension work Be i get to the engin..but i was wondering.. i want to go turbo... i know my stock block is going to blow sooner or later after the install..but i want to make sure that all the part i install, ( heads,u/l intake, water pump, etc..) will fit on the new block (a dart 302).
if i stroke it will all those parts fit in the new block as well...what do i have to look for in capability????
:SNSign:
okay so you want to do a turbo build up? I assume this isn't your daily driver?
You have two options:
1. Put the turbo on your stock engine, wait until it explodes then build your new engine with the dart block, good heads, etc.
2. Build up your whole car meaning dart block, HCI, rear end, transmission, etc. Then save up for the turbo at a latter date.
Currently I am doing option number 2 I would rather do things right and not break everything. But the choice is up to you.
