Building a 347 stroker
  • Thread starter Thread starter 83 Capri 5.0
  • Start date Start date Nov 19, 2006
1 of 2 Next Last
83 Capri 5.0
92
Vancouver, Canada
Nov 19, 2006
  • Nov 19, 2006
Got to do it on the cheap so I have to reuse everything basically. Will I be choking it if I put my old parts on it?
GT40 iron heads ported
Explorer intake honed
24lbs injectors (too small?)
Stock fuel lines and rails
190lph pump
1.7 roller rockers
E303 (will this cam work?)
65mm TB/EGR spacer
73mm MAF
1 5/8 shorties (will probably go long tube)
On a stock 89 block this combo ran a 12.53 @107 could I see high 11s with the 347 and a tune?
On other threads you guys talked about 28oz as aposed to 50oz balancer/flywheel
dirtysohc said:
The only time you need to go to a lighter balancer is if you plan on turning higher RPM's. I've had many engine combos over the years turning between 6500 and 7000 RPM and always with a 50oz balance. I would say if you were to go above 7000 Rpm's I would go with a 28oz or 0oz internal balance at that point. But just switching to a stroker set up doesn't nessecitate changing the 50oz set up.
90mustangGT said:
Your right dirtysohc, but most kits come as 28oz and to have them balanced to 50oz takes a lot of cutting on the crank and unless you "got the hookup" then it is quite expensive so it's almost cheaper to go 28oz and it does have it's advantages. I don't understand why the companies that make strokers dont' do 50oz because most of what it's going into is 50oz setups. They would sell more of them.
I went with a SFI balancer (pioneer) with a Alumimum Flywheel (spec) so of course mine cost a little more.
Rick 91GT said:
Yes you can go 50oz but it takes a lot of material out of the counter weights, to do it properly it should be taken off radially which is expensive. Going to the lighter inblance in better on parts and bearings.
Is it preference maybe, but I think you'll find most builders prefer the 28oz or internal balance over the 50oz on stroker combos, cast or forged crank.
So I should just buy the 28oz balancer/flywheel and no problem?
Does a stock block have to be bored out to a 306 to make work with the 347 kit? (I'm sure heard that it does)
Thanks in advance for your info!
Modular2v
3,222
23
99
oklahoma
Nov 19, 2006
  • Nov 19, 2006
you wont be choking it off. . . you just wont be using its full potential. My 331 went 12.0s and 11.10s on production heads
Modular2v
3,222
23
99
oklahoma
Nov 19, 2006
  • Nov 19, 2006
you can have the motor balanced to whatever you want (50oz,28 or 0) Yes a 347 is punched .030 over. . . if you dont then you have a 342. I dont think you will see high 11s at all, you will need a better cam and heads to get to the 11s
83 Capri 5.0
92
Vancouver, Canada
Nov 19, 2006
  • Nov 19, 2006
So are most of the 347 kits intented for use with a .30 over block?
83 Capri 5.0
92
Vancouver, Canada
Nov 19, 2006
  • Nov 19, 2006
do you think I will have a lean problem with the 24lb injectors?
331 or 347 for drag racing, which would you build?
83 Capri 5.0
92
Vancouver, Canada
Nov 19, 2006
  • Nov 19, 2006
What is the differences between flat top & dome top pistons in stroker kits?
stykthyn
5,232
2,652
223
gainesville
Nov 20, 2006
  • Nov 20, 2006
^^ subscribed
Flavadave4
1,044
21
49
Utica, NY
Nov 20, 2006
  • Nov 20, 2006
Jeeze thats not bad at all
Modular2v
3,222
23
99
oklahoma
Nov 20, 2006
  • Nov 20, 2006
YES, if you order a 347 kit you will HAVE TO have the block bored .030 over which is only about 125$ at most machine shops, you will also have to have the cylinder skirts notched in order for the rod bolts to clear (another 75$) If staying NA i dont see any reason why the 24lbs wont be enough and give you room to grow, the stock injectors can support 400hp. For racing purposes it is strictly personal choice between 331 and 347.(i built a 331) The 347 will wear out the block faster due to the angle the rods will want to push the pistons against the cylinder walls.....(this is all in theory and hear say). Flat tops are exactly what they say. . . they are level with the blocks deck and most have valve reliefes cut for piston clearence. . . dome pistons are domed above the deck of the block and also have valve reliefes. . . most people go with domed pistons in order to gain more compression and depending on the size of the cylinder head combustion chamber you might not be able to run pump gas at all. Keep in mind that if you plan to go ever go with a canted valve style head (such as twisted wedges) You want to be sure that the valve reliefes allow for that also! I would suggest going with probe as they have valve reliefes for both inline and canted valve heads
Modular2v
3,222
23
99
oklahoma
Nov 20, 2006
#10
  • Nov 20, 2006
  • #10
well its not good but its not bad. . . . they are ported c9s (which are for sale now if anyone is interested) I just got a set of twisted wedges so the car will be going 10s next season
1991vert
1,103
Ludlow, MA
Nov 20, 2006
#11
  • Nov 20, 2006
  • #11
24's i think are too small. hell, people were telling me i was going to choke my 347 with AFR165's/e-cam/performer rpm intake.
i upgraded to 185's, trickflow R-series, and kept the e-cam and re-used the 24# injectors, which i regret. but im adding a blower and new fuel system this winter anyways, so no biggy
83 Capri 5.0
92
Vancouver, Canada
Nov 20, 2006
#12
  • Nov 20, 2006
  • #12
I only have mild port GT40 heads and will not be able to add any other go fast parts so I guess small TB and smallish head willkeep the flow down so maybe the 24lbers will work for now.
Thanks for the info
I haven't seen any "budget" 331 kits yet, are they around?
I have seen 347 complete kits for around 6 to 8 hundred, am I asking for problems on the first run with these kits?
C
caseywan
157
Chicago, IL
Nov 21, 2006
#13
  • Nov 21, 2006
  • #13
Thanks for the info
If your talking about the eBay kits, I've heard a lot of bad stuff about them. The say is usually true "You get what you pay for".
aleborjas
610
#14
  • Nov 22, 2006
  • #14
the GT40 heads can work with a good port job and for the injector i'm building my engine with 30 pounds but with 24 is not too bad get more fuel press to help and for the kit i realy like propower (www.propowerparts.com) street strip kit they come with forged I rods (suports 600hp), forged Pistons (suports 1000hp) and bearings rings and stuff for 925 bucks not bad i have kit #990-213447ssft for $925
P.S The first thing you should do is change the cam stay away from alphabetic cams, get comp cams XE276HR-12 (35-328-8 good stroker cam) and is designed to be used with 1.7 ratio roller rockers.
R
r.barn5.0
107
#15
  • Nov 22, 2006
  • #15
limiting power with those parts..........
need better cam at least.
check out cam I used
CompCams XFI 236HR-14 - "Ford stroker 5.0L EFI cam"
94 gtr
11
Delaware
Nov 23, 2006
#16
  • Nov 23, 2006
  • #16
What kind of times you running with the combo in your sig?
60ft., 1/4 mile
thumper460
3,022
Orange Park , Fl
Nov 23, 2006
#17
  • Nov 23, 2006
  • #17
Just to steal the thread... There is a 347 Short block for sale in the " SE Classifieds" down lower on the "Southeast" menu.
28 vs the 50 oz! it really is up to the guy that you are going to get to balance!! 5 speed flywheel , he can use the 50 oz weight. and AOD, there isnt enough metal to make the balance!! 28 * is the choice of most all balancers for that reason!!
Pistons.. IF you are going to Blow or Turbo.. then the dished pistons are the better to keep the compression where pump gas can be used!! N/A then the flat top is good! Dome is a racing fuel only kinda thin.. cool??
Cam.. the E is a bit small for the 347!! Inexpensive cams?? the TFS2/ F303/X303. They are PROVEN Performance with 347!! The 24's will work fine on a street/strip engine!!
GT40s with the port work will be fine!! after the combo is deep into the 11's n/a then maybe think of upgrade to alum. Dont get into the gotta have BIG heads, and Custom cam thingy!! what you have will be a killer street/strip car and a blast to drive and 11 sec car on the streets!! IF you dont make the 11's it isnt the combo you are building.. cool??
Just me.............................
Thumper
EDC
342
63
58
In the new shop... 24/7
Nov 23, 2006
#18
  • Nov 23, 2006
  • #18
190lph pump
1.7 roller rockers
65mm TB/EGR spacer
73mm MAF
There is an old cliche' that holds true no matter what BS is spread throughout the internet...
"302 parts make 302 power"
Anyone who tells you the small stuff that works well on a 302 combo, works the same on a 347 is only blowing smoke up yer azz.
If you want to do this "on the cheap" then get a good cast steel crank, I-beam rods with forged piston package in the stroker kit. A really decent kit from Probe is just under $900 and it's plenty good enough for big torque and 350+ RWHP with the right peripherals.
Sell your iron heads and intake to a 302 guy and look for a used set of Twisted Wedge heads and a Holley Systemax 2 intake. These are about the minimum for a strong running 347 engine. Unless of course you want a 300 HP 347 that get's beat up by mild 302 cars.
Remember, a cheap combo is one thing, a stupid combo is another!
Ed
83 Capri 5.0
92
Vancouver, Canada
Nov 23, 2006
#19
  • Nov 23, 2006
  • #19
Any threads about the "bad stuff"? Would like to read about what I should stay away from.
Thanks,
Eric
83 Capri 5.0
92
Vancouver, Canada
Nov 23, 2006
#20
  • Nov 23, 2006
  • #20
Have to keep the e303 cam for now, but will keep that comp cam in mind for the next up grade.
Thanks!
1 of 2 Next Last
Weber Carburetor tuning help
  • SchwarzStock
  • Jul 6, 2026
1965 - 1973 Classic Mustangs -General/Talk- Jul 19, 2026
SchwarzStock
Exhaust 1 3/4” Long Tubes on a Fox Body AOD – Easiest route?
  • 5.0 Mike
  • Mar 19, 2025
2K
Fox 5.0 Mustang Tech Mar 21, 2025
5.0 Mike
  • 68_Disgustang
  • Feb 22, 2026
1965 - 1973 Classic Mustangs -General/Talk- Oct 19, 2026
mattcrp1
M
  • Locked
Engine Might have to get a Dart block but don't want to and if I do, then 363 instead of 331. Thoughts on what I've already bought so far.......
  • from6to8
  • Jul 8, 2025
Fox 5.0 Mustang Tech Jul 8, 2025
N
Vibration issue
  • Nicolaj
  • Apr 14, 2024
2K
Classic Mustang Specific Tech Nov 8, 2024
AeroCoupe
