Built Rear?
  • Thread starter Thread starter TrickFlowd
  • Start date Start date Nov 12, 2007
TrickFlowd
240
Sayre, PA
Nov 12, 2007
  • Nov 12, 2007
I'm getting close to my quota to start my built rear project. Any suggestions? I plan to do 5 lug conversion with rear disc. I'm hoping!
I plan to do 31 splines, rear girdle, and a 31 spline trac-loc with 4.10's and all new bearings and seals in a 94-95 rear housing with rear disc. Will 17x10.5 wheels clear everything with 94-95 rear? Will my 4.10's from my 91 work in a 94-95 rear? Any other suggestions on built rear? My goal is to reach 400 + whp after DSS 331 bottom, just want a rear that will hold more than 500hp.
Would you guys leave rear drum with 5 lug conversion and do 03-04 cobra front brakes with 5 lug? Or do 94-95 5 lug disc conversion in rear? The car is mainly a street drivin car, with occasional strip driving. I just thought if I stayed with drum rear, I could put the money elsewhere, that is if rear disc isn't necessarily needed.
Thanks!
TrickFlowd
240
Sayre, PA
Nov 12, 2007
  • Nov 12, 2007
no mustang gods tonite?
D
DREAMZOFHIRPM
40
BROOOOOOOKLYNN
Nov 12, 2007
  • Nov 12, 2007
u said more street then strip u might want to go 3:73 autos can do 4:10 better then 5 speeds,, ..... ive seen people with 28 spline be fine all the time with 500 hp numbers,,, as long as your not running full slicks... but 31's better get some moser axles auburn differential,,,, and look up a company called LPW .....
http://www.lpwracing.com/
they make a realll good rear end cover for added strenaght and then you can add their rear end brace that works hand in hand with their differential cover, check their site out....i currently run theyre diff. cover and have the brace on my table just gotta find time to weld it in....
TrickFlowd
240
Sayre, PA
Nov 12, 2007
  • Nov 12, 2007
What kinda price range am I looking at to run 31 splines with new diff, and rear girdle?
87 lx 4cyl to v8 project 4 lug disc conversion questions
  • 87lx428
  • Mar 24, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 25, 2026
87lx428
Which SN95 axles for 93 LX, disc brakes, ABS rings?
  • dan50
  • Mar 22, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 3, 2026
7-UP BILL
Rear Disc and Rims Offsets
  • TripleYellow
  • Nov 11, 2025
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jan 9, 2026
TripleYellow
C
SN95 Another Coyote swap list
  • catkiller
  • May 10, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 8, 2026
bjornsn95
J
  • JasonB66
  • Jul 23, 2026
  • Suspension
Suspension Jul 23, 2026
JasonB66
J
