Bummed out - Need 5.0 Help
Blakthorn
299
US
It was a nice day today so I was poking my head in the engine bay to check everything out before going for a ride, I put in some transmedic for the automatic transmission to keep it running smooth and also lucas fuel treatment and also replaced a cracked vacuum line.
I drove it around for about 15 minutes and in a parking lot on the way home as I was waiting for the light it jumped to 2,000 rpm and felt like it wanted to move even though my foot was on the brake...I put the car in park and shut it off - Now it wont turn on... It tries to engage, I hear the fuel pump click on when the key is in the on position, when you turn the key you hear it trying hard to go on (not the click of a bad starter) but it wont go, I had to get it flatbedded home via triple A - seriously bummed and all thoughts are popping into my head, even considering selling it
More important, is I need to know what the heck went wrong? Im working all weekend and have no time to get it to the mechanic if I cant fix it - Is it possible for that lucas fuel crap to clog up or mess up a fuel pump? After it bounced around on the flat bed tow truck and I took it off it sounded like it almost started, im counting on you stangnetters to help me out
:bang:
I would charge the battery or put a jumper on there (and check the battery connections) and see what happens when it starts. Go from there.
Good luck.
Thats done, plus all the lights and horn and all work....everyone has got me thinking that its not getting the fuel, but the only recent things I did was the auto trans fluid and the lucas gas treatment - i have a question what does that plastic piece above throttle body do (has 2 screws on it)
Throttle position sensor may be what you speak of.
That part could explain the rpms going to 2 grand, since when mine went bad it did that.
But i don't think it will keep the car from starting.
Look for a write up on how to check the TPS voltage.
Cranks OK, but No Start Checklist for Fuel Injected Mustangs
1.) Remove push on connector from starter solenoid and turn ignition switch on. Place car in neutral or Park. Remove coil wire from distributor & and hold 3/8” away from engine block. Jumper the screw to the big bolt on the starter solenoid that has the battery wire connected to it. You should get a nice fat blue spark.
A.) MSD or Crane ignition box if so equipped
B.) Coil
C.) TFI module
D.) PIP sensor in distributor
E.) ECC relay next to computer - look for 12 volts at the fuel injector red wires
F.) Fuse links in wiring harness - look for 12 volts at the fuel injector red wires. All the fuse links live in a bundle up near the starter solenoid.
G.) Ignition switch - look for 12 volts at the ignition coil red/lt green wire.
H.) Computer
See the following links for wiring diagrams...
http://www.autozone.com/servlet/UiB..._us/0900823d/80/16/71/3c/0900823d8016713c.jsp for 79-88 model cars
http://www.autozone.com/servlet/UiB..._us/0900823d/80/19/59/5a/0900823d8019595a.jsp for 89-93 model cars
http://www.autozone.com/servlet/UiB..._us/0900823d/80/1d/db/3c/0900823d801ddb3c.jsp for 94-98 model cars
2.) Spark at coil wire, pull #1 plug wire off at the spark plug and check to see spark. No spark, possible failed items in order of their probability:
B.) Distributor cap
C.) Rotor
D.) Spark Plug wires
Two reasons:
Clue – listen for the fuel pump to prime when you first turn the ignition switch on. It should run for 5-20 seconds and shut off. To trick the fuel pump into running, find the ECC test connector and jump the connector in the lower RH corner to ground. See http://www.mustangworks.com/articles/electronics/eec-iv_codes.html for a description of the test connector. If the relay & inertia switch are OK, you will have power to the pump. Check fuel pressure – remove the cap from the schrader valve behind the alternator and depress the core. Fuel should squirt out, catch it in a rag. Beware of fire hazard when you do this. In pinch you can use a tire pressure gauge to measure the fuel pressure. It may not be completely accurate, but you will have some clue as to how much pressure you have.
No fuel pressure, possible failed items in order of their probability:
C.) Clogged fuel filter
D.) Failed fuel pump
E.) Blown fuse link in wiring harness. Look for 12 volts at the Orange/Lt Blue wire on the fuel pump relay. The fuse links live in the wiring harness near the starter solenoid.
F.) Fuel pressure regulator failed. Remove vacuum line from regulator and inspect for fuel escaping while pump is running.
Fuel pressure OK, the injectors are not firing.
A.) A Noid light available from Autozone, is one way to test the injector wiring.
B.) I like to use an old injector with compressed air applied to the injector where the fuel rail would normally connect. I hook the whole thing up, apply compressed air to the injector and stick it in a paper cup of soapy water. When the engine cranks with the ignition switch on, if the injector fires, it makes bubbles. Cheap if you have the stuff laying around, and works good too.
a.) Pull an injector wire connector off and look for 12 volts on the red wire when the ignition switch is on.
b.) No power, then look for problems with the 10 pin connecter (salt & pepper shakers at the rear of the upper manifold).
c.) No power and the 10 pin connections are good: look for broken wiring between the orange/black wire on the ECC relay and the red wire for the 10 pin connectors.
4.) Spark & fuel pressure OK.
A.) Failed IAB (no airflow to start engine). Press the throttle ¼ way down and try to start the car.
C.) Engine ignition or cam timing off: only likely if the engine has been worked on recently).
HO & 351W 1-3-7-2-6-5-4-8
Non HO 1-5-4-2-6-3-7-8
E.) No start when hot - Press the throttle to the floor & try starting it if you get this far. If it starts, replace the ECT.
come to think of it, i started the car with the air duct off, so basically just throttle body meeting open air but i am speed density so could this have affected something?
btw thank you for the detailed response
If your SD, it doesnt matter if you have the air inlet hooked up.
JR's list will find your issue. If/when you get to spots on the list where you find something a bit off, post your concern and the smart folks in here can interpret it or tell how to fix it.
If I read ya right, it wont even crank. The starter draws about as much as anything on the car, so though the lights work, that's not a valid test. If it wont crank, post what you did to test it exactly (or search Jrichker cranky list [oh wait, that would be no crankie list. :D ]
Good luck.
It cranks as if its about to turn on but it just wont.
The last time I had a starter problem it would just click, this is totally opposite, I go past that at least, It cranks and turns and turns and it just wont engage
do you think that lucas fuel treatment could have any affect on the fuel pump or fuel filter if there was not a lot of gas in the tank when it was poured in?
The bottle says 2-3 ounces per 10 gallons, although I didnt measure it, I doubt it would mess up etiher......im confused because i just took it for the good weather this last week and havent had a problem until today
so are you saying the starter is turning the motor over? is it turning at the normal speed as to if it was to start, but just won't. or is the starter spinning and not engaging the flywheel? just that whirrrrr sound.
If your starter is going out (could be the bendix) you can try to whack your starter with a hammer a few times to see if it engages. Does it sound like the motor is turning over, or just the starter? My taurus did the exact same thing.. whacked it a few times with a hammer, and she started right up. I doubt this is your problem, but its the only thing i could think up at the time :shrug:
the starter and solenoid are new, the motor is trying to turn over, its not a starter problem, because when the starter didnt work last time it was just a click when you turn the key, now i at least get the engine turning over, as if it were not getting fuel, even if i pump the gas as its trying
i had the same thing happen to me ( but no lucas fuel stuff) but mine was simple on the passenger side of the engine there was a single hose that was not on, (must have fell off or something). and that was keeping it from starting it was the exact same way your describing it so if you havent, check all lines especially that one on the passenger side.
wait a sec, i think that line might be cracked, what is it for, its pretty short, it goes back from the ac canister to a metal cansiter to the left of the engine right?
whats it do?
no thats just for your a/c, if its for your a/c then it shouldnt be keeping you from starting your engine. Im talkin about your air check valves they are down by the headers only on the passenger side, they control your air injection system and air bypass valve and other various things but check the connections on all those. they have control vacuum lines on the top of them. check em.
whats it do?
Please refer to items as being on the passenger or driver side, not left or right.
Convention says that if one uses left or right terminology, it is as viewed from the driver seat. But many folks reference left and right as seen from the front of the car, which leads to confusion.
This can help folks to get you up and running quicker. :nice:
