car steers horribly, i know i need a bumper steer kit. so my question is does anyone have any recommendations? what are you using? if it matters i plan on installing sportline springs too. thanks
wazazzle said:when i drive on the highway, some lanes have those deep grooves from semitrucks. when ever i'm in those lanes it like the steering yanks out of my hand and weaves into other lanes-n-$hit. even if i fight it. i can literally feel when i'm riding up or down a grooves. all stock susp so far.
wazazzle said:thanks guys for the helpseeing how its all stock. it's probably best if install new steering rack, should correct probl. will install c/c kit when springs installed too.
crazypete said:Increase toe in dude!
Reduces the effect of the tramlining as well. Trust me on this one. Before I did this, my 225/60/r15 factory tires would tramline on rte 2 out near lexington where they have some wicked grooves in the highway. 1 1/2 turns in on each tie rod and it's gone.
crazypete said:Something for something. The factory setup is that way for a reason and deviation from it will incur some sort of compromise. I say if you can afford to fill your car with racing parts then you can afford to switch tires a bit more often than usual.
