Burning Coolant
water leaking into 98 4.6 engine
  • bad intake
    Votes: 0 0.0%
  • bad head gaskets
    Votes: 0 0.0%
  • Total voters
walter green
i have a 1998 gt 4.6 mustang and sometimes when started white smoke comes out .i think its burning coolant but not sure where its burning from intake or heads .i have heard ford had problems with the intakes .and what to know if can install a later after market onto the 98 heads or engine ,thaks walter
There's really not enough information here to determine what's going on. If you pull the radiator cap, can you see any bubbles coming up through the radiator? That's a sure sign of a bad HG.
Pull the plugs, are any of them particularly clean? If so, that cylinder may be the issue as water tends to steam clean the cylinders.
Then, run a compression test.
Or, yeah, just ignore any testing and throw parts at it. Your money.
Yes, the PI(99-04 mustang) intake can be bolted on. Use PI gaskets and you'll have to put a couple of dabs of silicon in a key spot to seal correctly. You'll get a nice ~15hp bump in power to boot. Do a search and you'll find hundreds of write ups.
no its just i have had 5 back operations and sometimes its hard for me to reason things out .i have no one here to help me . this is a nice looking car and im just trying compile as much advice as i can .i know theres alot of wise people out there that can advise me.and its not that i wont test things out.walter
