Burning Oil+
  • Thread starter Thread starter davs427
  • Start date Start date Sep 9, 2013
davs427
10
  • Sep 9, 2013
I obtained a motor that was recently rebuilt.(Verified) Procomp 2.02 heads and adjustable roller rockers came with. I heard the motor run in another car and ran smooth without smoke. I got the motor with the heads off. Installed a custom cam installed straight up and reassembled the motor. I used an adjustable pushrod etc and got new push rods. Cobra intake bbk 70mm, 30lb injectors and matching mass. Rockers carefully adjusted at just less that 3/4 turn. New PCV valve.
On start up I have a plume of blue smoke. Smokes at idle and more when I give it gas. Just did a dry/wet compression check and across the board I have 110lbs with lil bump when a wet test was done. Rings ruled out. The back two cylinders #4 and 8 are wet with oil. The neighboring cylinders #3 and 7 are a tad wet w oil. The others all look great. NO water in the oil. The car idles ok and revs quick. But doesnt sound quite right. When under load it farts a little and definitely doesnt have the power it should. Whistle develops in the intake. ANY IDEAS??
I was hoping to get more of a definitive idea instead of just yanking the heads and off to the machine shop. Could this be just a gasket issue? Timing? It uses quite alot of oil. Although it made me smile when I polluted a Prius that had full anti stickers when on the way to work.
JD1964
there is enough sticking out to grab on to
3,599
1,610
194
Maryland
Sep 9, 2013
  • Sep 9, 2013
Is it possible someone forgot to install valve seals when the heads were assembled?
davs427
10
  • Sep 9, 2013
Definitely possible. But it wasn't smoking when I saw it run. In fact on my first start up it didn't smoke this bad.
madspeed
Colonel Mustard
1,332
204
a van down by the river
Sep 9, 2013
  • Sep 9, 2013
recently rebuild motor and a compression test shows 110 psi??
mikestang63
SN Certified Technician
Aug 27, 2012
11,606
8,859
214
In the garage
Sep 9, 2013
  • Sep 9, 2013
head gaskets on properly and torqued correct? 110 PSI is not good. Either your motor is weak or you assembled it improperly. The fact the back plugs are oil soaked leads to me gaskets- intake- head- are not on right.
84Ttop
5 Year Member
Jul 2, 2009
5,222
3,254
204
South Jersey
Sep 10, 2013
  • Sep 10, 2013
wont cause it to smoke that bad, mine have no seals on any of the exhaust valves and the car doesn't smoke a bit.
I would definitely look towards a bad intake gasket, could have slipped out of the way during the install?
01Laser
25
  • Sep 10, 2013
It really sounds like the intake gasket was maybe not installed correctly or it wasn't new/in good condition to begin with.
Maybe this will help checking
View: http://www.youtube.com/watch?v=_1ZQSLpxwX0
T
Oil burning on my recently buil 302
  • The blk67
  • May 15, 2026
Fox 5.0 Mustang Tech May 15, 2026
Engine Looking for suggestions and or ideas
  • PonyGTrider
  • Aug 25, 2026
PonyGTrider
A
Engine 302 oil leak when running
  • AlexM556
  • Sep 8, 2026
Classic Mustang Specific Tech Monday at 4:43 AM
manicmechanic007
Running very very rich
  • 2esoteric
  • Oct 31, 2025
Fox 5.0 Mustang Tech Oct 31, 2025
Engine Gas in my oil
  • limp
  • Jun 15, 2025
2K
Fox 5.0 Mustang Tech May 16, 2026
Mindseye007
