Buying a C4, which bellhousing?
afterglow
89
I'm looking to buy a C4 to replace my C6. The guy I'm buying it from is unsure where the C4 came from. What should I be looking at to make sure that it'll bolt up to my 74 351W??
Also, the guy says there's a small crack in the bellhousing. Is this easily repairable or should I look elsewhere?
crack?
aluminum welding is expensive....watch out. I`d just get a different bell.
Oh, a lesson I just learned recently too, the bell type depends on the car its going into, if you have a 65 or 66, your gonna need a 157 tooth bellhousing, cause the larger one causes issues. After that I dont think it matters much (someone correct me if I`m wrong) cause the transmision tunnel grew quite a bit in 67 and later models.
In Summit, they have two casefill bellhousings that'll fit the C4/351W (TCI-513300 & TCI-513310, both by TCI). The only differences I see are one is 5.875" deep and the other one is 6.75" deep. Which is the right one for my application?? Or am I looking in the wrong place?
