Shakerhood said:I seen this on an Automotive TV show last night on the DIY Network and they said those lines are to keep the throttle Body warm as the throttle blade will ice up.
Darkwriter77 said:Shakerhood beat me to it. F-Body cars (Camaro/Firebird) equipped with TPI motors have the exact same thing, a coolant inlet/outlet going through the throttle body, and it's listed as a "throttle body pre-heater," which simply, as stated above, serves to prevent the throttle body from freezing up in severe cold conditions.
found in this very good EEC-IV Tech Article or check Al Kirschenbaum's 5.0 Reference book on the SEFI EGR section. This one BTW, has a 5.0 with both ports capped on its cover photos, talk about irony. GLEEC-IV Tech Art. By John Hunkins said:A valve on the side of the EGR spacer opens and closes to control the flow of exhaust into the intake. As the exhaust gas can add much heat to the intake manifold and incoming air, it is plumbed for engine coolant circulation. (A line on the front of the spacer feeds coolant to the spacer and a line on the back takes coolant away.)
conv91lx said:Unless you block off the egr passage, don't do this. The coolant is to cool your egr spacer. Not to warm it, to keep it from freezing, wtf? If you do this with hot exhaust gasses still passing through it, it will get extremely hot and eventually cook your gaskets. (don't ask me how I know this, just chalk it up to "live and learn"). The coolant passing through, is far cooler than the gases being circulated. I actually believe bypassing the lines would hurt performance. Although this is probably so minimal as to not even be measurable.
fox racer said:but cooling the egr gasses doent explain the excesive carbin build up cause by the cooling, and also why ford didnt integrate the 'cooling' lines into the cobra intake.
