C&L intake with modded PCV system hose
GreyDiesel
167
Denver, CO
I bought my C&L intake used, and it has a rubber hose where the PCV hose should be. What is up with this? I am guessing they did this for a reason... Maybe they somehow broke the previous PCV hose, and this was fabbed as a replacement. Is their any advantage to a wider PCV hose? Should I use my stock PCV hose instead?
see red arrows in attached pic.
I have a Steeda intake, and removed the PCV system for the drivers side, and replaced it with a simple push on miniature air filter. On the passenger side, I installed an oil separator in-line, to prevent oil from being sucked into the butterfly valve assembly. Its not PC nor will it pass inspection, but.....
