C&L Plenum
jrc_03_gt
786
Can a C&L plenum and a upgraded throttle body improve performance with the stock intake ductwork still intact? Do you have to have a cold air intake to get the most out of it? I only have K&N air filter and 40 series flowmasters for my current mods. Is it a waste of money if I dont plan on doing lots of other mods? C&L claims 9-14 hp gains then another 4 hp with upgraded throttle body. The C&L ad is in the new pro 5.0 and super fords mag. Is this worth my time and money with just the few mods I have? Does the computer need to be reprogramed?
i got just the plenum and didn't really notice much of a difference. i have a 70mm throttle body, maybe that why. having a cai won't give you any more noticiable difference with the plenum, although i do have a trueflow pipe on the way (and if you see my torque numbers bleow, you'll understand). i'd say the whole setup, plenum and 75mm throttle body, may be worth 5-7 rwhp on a fairly stock car.
I am assuming your numbers are not SAE corrected unless you have every possible bolt-on + a good tune.
I have a Mac CAI feeding the Accufab 75mm TB & C&L Upper Intake Plenum. I can't say for sure whether or not the CAI helps since it was the 1st of my intake mods. But I most def saw a noticeable increase when the TB/Plenum combo was installed. W/ 4.10s I can burn rubber all the way through 2nd.
Are you saying the you couldn't burn rubber through 2nd without the TB/plenum combo?
I'd think 4.10's would take care of that.
I had the Accufab 75mm TB and C&L Plenum for a short time with the stock rubber intake tube. It still felt much stronger even with the stock tube on there. The only thing is its a PITA to get that tube to fit onto the bigger throttle body.
