I installed this stuff over my lunch break yesterday:
- C&L MAF (80 or 85mm, I can't remember rith now!) kit w/K&N
- C&L TrueFlow pipe
- AccuFab 75mm TB
- C&L plenum
I got it all at
http://www.rpmoutlet.com for abt $750 with free shipping.
It took 1 1/2 hours and I had these problems:
- The connector on the back of the plenum was too big for the hose that goes there (I made a make-shift adapter to reconnect them)
- The pipe did not fit under my strut tower brace (I think it is stock on the verts); I had to loosen the brace to get it in.
- I did not have time yesterday to disconnect the battery and now I am getting a check engine light.
- It pings alot when under a load (the T/A is set to 14 and I use 93 octane all the time); I'm guessing it is too lean.
This afternoon I disconnected the battery for an hour and re-did the hose connector (still not happy with it but it's better). I just reconnected the battery, but I haven't had time to drive it yet to see how it is.
I'm still not sure what to do about the brace, I'll probably try to put a spacer under the top bolt to lift it or something like that.
