  • 1994 - 1995 Specific Tech
C4/C6 trans.
  • Thread starter Thread starter Emoney8924
  • Start date Start date Aug 9, 2006
Emoney8924
77
columbia, ct
Aug 9, 2006
  • Aug 9, 2006
hey guys, i posted this other places but no one responded, maybe a dumb question but whats the difference between these two transmissions?? my aode seems to be slipping, i dont know if its the t.c or just the trans, in general, when i got the car, the housing on the back of the trans. was coming off, the bolts were backed out, so im guessing someone really kicked the **** out of this poor car... correct me if im wrong the aode is a 4 speed auto, and both the c4 and c6 are 3 speed autos?? will this effect highway driving, top speed, gas mileage?? or anything, and im assuming the c4 and c6 will take more power than the aode.. and will these transmissions bolt right up to my engine?? (95GT) sorry for the 21 questions guys, but thanks for the help!!!
reddy351
560
12
38
Columbus, Ohio
Aug 9, 2006
  • Aug 9, 2006
The C4 is best behind almost any smallblock. The C6 is best behind big blocks or pick-up trucks that do a lot of towing. The C6 is MUCH beefier where it counts, but is a lot heavier, where it counts. The internals are lighter for the C4, reducing parasitic drag. You're right about the 3/4 speed differences. No OD means the engine will be spinning faster at highway speeds, technically, using more gas. The AODE can be made just a strong as the C4, which is almost bulletproof, if built properly.
You can spend the same $$$ replacing the AODE as rebuilding it. I would forget the C4/C6, unless you are building a full time drag car. The optimum solution for your situation is to buy an aftermarket rebuild AODE from Jeg's or Summit. The trans and convertor will set you back about $2000, but you will NEVER need to worry about it. A "Jasper" type rebuild will run you about $1200-$1400. Finally, a "generic" rebuild can cost as little as $700-$800. You can find the generics on Ebay and you local discount parts store. Good luck with your choice.
K
3.8 T5 & Bellhousing to 1987 Lincoln 5.0
  • ks65stang
  • Mar 2, 2026
  • Other Auto Tech
Other Auto Tech Mar 3, 2026
V6 to V8 Swap info
  • 02_2v_Curtis
  • Jan 11, 2026
1996 - 2004 SN95 Mustang -General/Talk- Oct 7, 2026
2v_johnny
C
AOD wont go into park
  • chris1993
  • Mar 4, 2024
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 28, 2024
Silverfoxx
SN Mustang Magnum T56 swap
  • revhead347
  • May 24, 2024
7K
1994 - 1995 Specific Tech Jun 28, 2026
GearHeadGuy
67 c4 and block to aode and 302 computer upgrade
  • sp33dbump
  • Apr 12, 2022
1965 - 1973 Classic Mustangs -General/Talk- Apr 20, 2022
Mcmahst
